Rubber rubbing blocks around gas-tank., Looking for position of rubber blocks. |
HansJan |
May 20 2016, 09:51 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
To prepare for the installation of the Tangerine solid fuel lines, I pulled the tank out of the car. Two large rubber blocks fell out. Now I am trying to figure out where to place these blocks when the tank goes back in. Does anyone know?
Additionally Im am looking for new lug nuts. The car has five-lug fuchs rims. But the seller put mismathed nuts on. Mismatched meaning; the conical part of the nuts do not match the concaves in the rims. I still have some aluminum nuts (from my 911 days), but these used to break. Looking on the web I cant find steel black nuts to match the rims. Does anyone here have a solution for this? |
Amphicar770 |
May 21 2016, 08:39 PM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Here is a tip for when you put tank back in. The rubber fuel lines will want to kink, especially near where they connect to tank.
The trick I discovered ,the second time I pulled the tank, is to loop the hose which a lot of folks will tell you. I put a loop right near where the hose connect to the tank. I then used a loose fitting zip tie to secure the loop to the metal that the hose connects to. Unlike the first time around, dropping it back in without kinking the hose was a piece of cake. You did not mention the year of your car but if you have the 3 port pump, now is a good time to replace it with a new 2-port. They are inexpensive and doing it now will avoid the second tank pull while eliminating the Y-connection also means one less hose to deal with and fewer clamped connections likely to leak. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:59 AM |
