WCR AX In-Car video from my run ... |
SirAndy |
May 22 2016, 09:48 PM
Resident German Group: Admin Posts: 41,631 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Here's in-car video from my fastest afternoon run. Unfortunately, the camera is mounted a bit too low, i need to get an extension for the roll-bar mount to get it up higher.
The 1st lap was a 53.1 with the tires still somewhat cold and not gripping as well, the 2nd lap was a 51.2. I'm running on 10" GoodYear R250 slicks. (IMG:style_emoticons/default/driving.gif) https://www.youtube.com/watch?v=ZsOUzMKooVI |
914werke |
May 23 2016, 07:37 AM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
was it that one or the last that the battery jumped the tray?
SirAndy |
May 23 2016, 11:12 AM
Did I hear something rubbing? was it that one or the last that the battery jumped the tray? Yes, if you listen closely you can hear a loud "thumb" right before i get on the main straight for the first time. That was my battery coming lose and laying on top of the engine for the rest of the run. (IMG:style_emoticons/default/wacko.gif) |
76-914 |
May 23 2016, 12:26 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Did I hear something rubbing? was it that one or the last that the battery jumped the tray? Yes, if you listen closely you can hear a loud "thumb" right before i get on the main straight for the first time. That was my battery coming lose and laying on top of the engine for the rest of the run. (IMG:style_emoticons/default/wacko.gif) Crap! OK, now tell us why it came loose so we can avoid a similar situation. Also, was there any collateral damage? |
SirAndy |
May 23 2016, 12:40 PM
Crap! OK, now tell us why it came loose so we can avoid a similar situation. Also, was there any collateral damage? No damage. I have a redtop optima and i've been using their plastic holddown for years. It felt tight before the run and i did pass tech inspection (the guy did check the battery and it didn't move). It looks like that the mounting hole for the holddown is about 2mm off and the rounded edge doesn't sit flush against the battery. So all that is preventing it from moving is the clamping force between the front of the holddown and the battery base which apparently wasn't enough. (IMG:style_emoticons/default/idea.gif) Once the battery moves even just 2mm, it'll slide out of the back channel and is free to go wherever it wants to go. (IMG:style_emoticons/default/unsure.gif) |
Dave_Darling |
May 23 2016, 03:12 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Once the battery moves even just 2mm, it'll slide out of the back channel and is free to go wherever it wants to go. (IMG:style_emoticons/default/unsure.gif) That's why I asked McMark to set up a hold-down across the top of the battery for me. I had made one myself, but it was a POS and a major pain to install/remove. --DD |
Lo-Fi Version | Time is now: 11th May 2024 - 08:52 PM |
