How to verify crankcase oil level on a /6? |
tornik550 |
May 23 2016, 08:52 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I also posted this on pp however I usually get better responses here.
I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? |
tornik550 |
May 24 2016, 05:54 PM
I have a late model 911 tank that does not have a console.
I drained the tank and there was roughly 5 qts. I also drained the engine and there was a lot of oil there! After everything was drained as though I was changing the oil, I then filled the oil tank back up with about 5 qts. I plan on just running it like that and then checking the oil level when the engine is hot. |
Lo-Fi Version | Time is now: 20th May 2024 - 08:15 AM |
