How to verify crankcase oil level on a /6? |
tornik550 |
May 23 2016, 08:52 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I also posted this on pp however I usually get better responses here.
I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? |
porschetub |
May 28 2016, 05:16 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Oh well guess I better recheck my console position,buggered if I know why?,my console is off a 75 911 and my tank is factory 914/6,it WILL NOT fit in 3 positions...the holes only allow it to go in one place as far as I remember.
Lo-Fi Version | Time is now: 20th May 2024 - 01:11 PM |
