How to verify crankcase oil level on a /6? |
tornik550 |
May 23 2016, 08:52 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I also posted this on pp however I usually get better responses here.
I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? |
Cairo94507 |
May 23 2016, 08:55 PM
Michael Group: Members Posts: 9,740 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I can't recall what a stock 6 holds at this point, but I guarantee you it is not 14 quarts. I do not believe it is even 12 quarts. In the back of my mind I am thinking 10.5, but could be wrong.
tornik550 |
May 23 2016, 09:01 PM
I can't recall what a stock 6 holds at this point, but I guarantee you it is not 14 quarts. I do not believe it is even 12 quarts. In the back of my mind I am thinking 10.5, but could be wrong. I believe that is correct. It clearly seems to be too much oil. That's why I am confused as to why it is not showing on the dipstick. Either there's a problem with my dipstick or for some reason too much oil is in the crankcase. |
wndsrfr |
May 23 2016, 09:34 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I can't recall what a stock 6 holds at this point, but I guarantee you it is not 14 quarts. I do not believe it is even 12 quarts. In the back of my mind I am thinking 10.5, but could be wrong. I believe that is correct. It clearly seems to be too much oil. That's why I am confused as to why it is not showing on the dipstick. Either there's a problem with my dipstick or for some reason too much oil is in the crankcase. OK... It's a dry sump setup. What happens is that the oil slowly seeps down into the crank case when the engine is off, then it's pumped back into the tank after startup. So, the crankcase is way overfilled on a cold startup. The only correct measurement is with the engine running and the oil hot. With engine running and the oil cold, it'll just barely wet the bottom 1/4 inch of the dipstick. The oil expands as it heats up and then it comes up to the dimple on the dipstick. I'm guessing that a bench setup with engine, stock oil cooler & tank with filter holds about 9 maybe 10 quarts. No harm in starting out with 8 and then add whats needed to get the right level after it heats up. |
Lo-Fi Version | Time is now: 9th May 2024 - 08:00 PM |
