How to verify crankcase oil level on a /6? |
tornik550 |
May 23 2016, 08:52 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I also posted this on pp however I usually get better responses here.
I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? |
mepstein |
May 23 2016, 09:50 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Checking engine oil level when cold. The classic 911/914-6 mistake.
Even one of our techs ( who REALLY should have known better) did it last year. |
r_towle |
May 23 2016, 10:09 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Checking engine oil level when cold. The classic 911/914-6 mistake. Even one of our techs ( who REALLY should have known better) did it last year. Checking is one thing, filling till it's right on the stick.....while cold... That is a whole nuther special smoke show... Btdt |
mepstein |
May 24 2016, 05:21 AM
Checking engine oil level when cold. The classic 911/914-6 mistake. Even one of our techs ( who REALLY should have known better) did it last year. Checking is one thing, filling till it's right on the stick.....while cold... That is a whole nuther special smoke show... Btdt Well he checked it, then filled it, then soaked the brand new air filter with oil...then cranked it ....again, he should have known better. (IMG:style_emoticons/default/dry.gif) He doesn't work for us anymore. |
Lo-Fi Version | Time is now: 9th May 2024 - 07:15 PM |
