How to verify crankcase oil level on a /6? |
tornik550 |
May 23 2016, 08:52 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I also posted this on pp however I usually get better responses here.
I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? |
tornik550 |
May 24 2016, 07:03 AM
I did have the oil pressure circuit modification done by ollies. The oil pump was new. I was able to get about 23 lbs of oil pressure by cranking the starter for a little (no ignition or fuel hooked up).
As far as the oil in the cylinders goes, I had cranked the engine a few times to make sure I could get appropriate oil pressure- then I went on vacation so the engine sat for a couple weeks. When I returned, that is when I found the standing oil. I think that I was relying on the dipstick too much. I am thinking that I just need to drain the oil as though I was going to change the oil, then put about 6-8 qts back in, run the engine then check the dipstick. What is the oil console? I tried to follow the info that I found in a different post regarding relative height of the oil tank. I supposed there could be something wrong with the height of the tank. |
6freak |
May 24 2016, 07:43 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
I did have the oil pressure circuit modification done by ollies. The oil pump was new. I was able to get about 23 lbs of oil pressure by cranking the starter for a little (no ignition or fuel hooked up). As far as the oil in the cylinders goes, I had cranked the engine a few times to make sure I could get appropriate oil pressure- then I went on vacation so the engine sat for a couple weeks. When I returned, that is when I found the standing oil. I think that I was relying on the dipstick too much. I am thinking that I just need to drain the oil as though I was going to change the oil, then put about 6-8 qts back in, run the engine then check the dipstick. What is the oil console? I tried to follow the info that I found in a different post regarding relative height of the oil tank. I supposed there could be something wrong with the height of the tank. its what the filter screws onto..sounds like its upside down and your just filling the motor and its not returning to the tank. good luck (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 07:00 PM |
