How to verify crankcase oil level on a /6? |
tornik550 |
May 23 2016, 08:52 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I also posted this on pp however I usually get better responses here.
I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? |
McMark |
May 24 2016, 08:30 AM
I'm not sure this was posted clearly.
You check a 911 engine while it's running. The engine must be running while you're checking the oil. You cannot check the oil with the engine off. (IMG:style_emoticons/default/biggrin.gif) If you're just test firing the motor, drain the oil again. Put in half of what you take out (should be 5-6 quarts based on your description). |
r_towle |
May 24 2016, 10:37 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I'm not sure this was posted clearly. You check a 911 engine while it's running. The engine must be running while you're checking the oil. You cannot check the oil with the engine off. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/bootyshake.gif) |
6freak |
May 24 2016, 11:06 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
I'm not sure this was posted clearly. You check a 911 engine while it's running. The engine must be running while you're checking the oil. You cannot check the oil with the engine off. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/bootyshake.gif) I agree too! but you dont wanna start it with out the proper amount or real close and flow so whos gonna ask him how long his dip stick is (IMG:style_emoticons/default/lol-2.gif) ... (IMG:style_emoticons/default/biggrin.gif) |
McMark |
May 24 2016, 02:54 PM
Lo-Fi Version | Time is now: 9th May 2024 - 08:33 PM |
