fix for self turn signal, self canceling turn signal doesn't work... |
frankieshooz |
May 23 2016, 10:41 PM
Member Group: Members Posts: 83 Joined: 23-September 14 From: Mill Valley, CA Member No.: 17,945 Region Association: Northern California |
newbie trying to learn the ins and outs if teener repair..wondering if there is a fix for my turn signal. right signal woks and cancels as designed but left won't self cancel which in itself is no big deal as long as I remember to manually flick stalk to neutral position...is there a fix for this that is not too difficult?
carcus |
May 23 2016, 10:58 PM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
newbie trying to learn the ins and outs if teener repair..wondering if there is a fix for my turn signal. right signal woks and cancels as designed but left won't self cancel which in itself is no big deal as long as I remember to manually flick stalk to neutral position...is there a fix for this that is not too difficult? I have to manually cancel both my right and left as well. I think it is a spring or something. Sometimes I forget and leave the turn signal on since it will not self cancel. Standing by for more info on this. |
RohJay |
May 24 2016, 01:39 AM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
Thanks for bringing this up; I have same issue with left not self cancelling.
whitetwinturbo |
May 24 2016, 10:37 AM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Mikey914 |
May 24 2016, 01:31 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check the steerign wheel assenbly, there needs to be a pin to knock off the signal. There were some plates with connector for the horn ring. May solve the issue.
914Sixer |
May 29 2016, 06:43 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Two things could have happened. The spring came off or the plastic ears that it mounts to broke off. Best to just order a new one.
Steve |
May 29 2016, 09:54 AM
914 Guru Group: Members Posts: 5,569 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I have the same problem and on top of that the horn now goes off when I turn the steering wheel. I ordered a new turn signal assembly from pelican. It was more expensive than some of the aftermarket ones. Hope it's a better brand for the money
Lo-Fi Version | Time is now: 25th April 2024 - 07:10 PM |
