Old school builds/Tried, true, tested....cheap trick, Common sense builds and ideas/ solutions for the "common man" |
Gunn1 |
May 25 2016, 09:06 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Much like my grandmothers recipe for Amish oatmeal chocolate chip cookies would have been lost forever if someone didn't take the time to write it down, it is similar that many of those on the site who comment or watch from a far have common sense low cost solutions to building a type 4.
Not really asking for your trade secrets or any self promotion, just common sense solutions that over the years have worked for you. Primarily want to hear folks low tech, low cost alternatives for repairing or rebuilding the type 4 or the 914. Anything as a permanent approved repair fix to a Macgyver fix that can get you by. Anything that works well in combination that you figured out on your own or with someone else's help. Again primarily looking for a dialog on low cost common sense technicis to type 4 repair and rebuild info. Cheap tricks. Thank you |
rick 918-S |
May 26 2016, 06:41 AM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
The bottom end of a type IV is nearly indestructible. If you are up to the task just do a top end rebuild. Most any machine shop can do valves and guides and seats as long as the heads aren't cracked. I made a resurfacing tool for touching up the surface where the head contacts the cylinder from a piece of MDF. Just stick a piece of 180 sand paper on it and turn it. Finish with 220. The sand paper is to just clean up the mating surface. I've used this method on several engines with great sucess. Low buck and it works.
Gunn1 |
May 26 2016, 08:45 AM
The bottom end of a type IV is nearly indestructible. If you are up to the task just do a top end rebuild. Most any machine shop can do valves and guides and seats as long as the heads aren't cracked. I made a resurfacing tool for touching up the surface where the head contacts the cylinder from a piece of MDF. Just stick a piece of 180 sand paper on it and turn it. Finish with 220. The sand paper is to just clean up the mating surface. I've used this method on several engines with great sucess. Low buck and it works. Now that's what I'm talking bout right there.... Great information, and using materials readily available for very little $'s Thank you |
Lo-Fi Version | Time is now: 18th May 2024 - 03:04 AM |
