Rebuild of doors, How does one get all the door hardware correctly assembled |
North Coast Jim |
May 26 2016, 03:24 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Spend the last day and a half attempting to assemble the passenger door with all new rubber. When I bought the car this aspect was in pieces so I didn't take it apart. Can't seem to find the correct procedure to enable all components to be correctly assembled. It's the aluminum channel at the top of the door, the one with a fuzzy inside and the window scraper on the top that is giving me an issue. Seems like I need to install the piece AFTER the glass is installed. When I attempt that there is no way I can get the glass down past to put in the 3 screws that hold it in place. Tried to assemble the channel first but a welded nut on the steel structure glued to the window bottom is too wide to fit the remaining opening. Being a Newbie I attempted to see if there was a thread that deals with this but found none. Please Help !! Off to have a beer now before I do something I'll regret. Car is 74 if that matters.
Mikey914 |
May 27 2016, 10:08 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Here's the thread I did, and the factory diagrams for both early and late -
http://www.914world.com/bbs2/index.php?sho...=230572&hl= |
Lo-Fi Version | Time is now: 27th May 2024 - 09:00 PM |
