914 Newbie. Got a few questions |
surfdogskier |
May 26 2016, 07:13 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Hey guys. New to the forum and new to a 1972 914 1.7L. Very excited to play around with it. I had a 1978 911 a few years back but my favorite has always been a 914. I got it for an even trade on a 1984 Thundercraft boat. I think I did pretty good.
It is in really good shape in and out. Car runs ok but I do have a couple of questions. 1. I changed the oil and it had a log of gas in it. What could cause this? Not driving it enough for it to evaporate (I read that somewhere). 2. I have also have a few hoses that don't go anywhere and open spots on the engine that look like they need those hoses. I just don't know what goes where. Can someone point me to a some open engine hatches for a 1.7. I can find 2.0's and conversions all over. Just not the one I need. 3. How do you check for vacuum leaks? I hear these are common on these Porsches. Again, thanks for any help. Excited to be part of 914world..... (IMG:style_emoticons/default/beerchug.gif) Jason Sevierville, TN |
era vulgaris |
May 26 2016, 07:31 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Here's a diagram for your 1.7 vacuum hoses. http://www.914world.com/bbs2/index.php?act...t&id=212385 If you have vacuum leaks with Djet, your idle will be high. You should be idling around 850-900rpm. If you're there, you're good. If you're above that you likely have vacuum leaks. Gas in oil is from leaky injectors or a leaky cold start valve. |
surfdogskier |
May 26 2016, 09:56 PM
(IMG:style_emoticons/default/welcome.png) Here's a diagram for your 1.7 vacuum hoses. http://www.914world.com/bbs2/index.php?act...t&id=212385 If you have vacuum leaks with Djet, your idle will be high. You should be idling around 850-900rpm. If you're there, you're good. If you're above that you likely have vacuum leaks. Gas in oil is from leaky injectors or a leaky cold start valve. That is exactly what I needed......Thanks! |
steuspeed |
May 27 2016, 12:09 AM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
EdwardBlume |
May 27 2016, 07:55 AM
Change all your fuel hoses and fuel injection rubber. You don't want to blow up. |
Lo-Fi Version | Time is now: 28th April 2024 - 01:12 PM |
