Oh dear-here we go again!, Running rich |
porschefile2010 |
May 26 2016, 07:49 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
I needed your help before and now we have a new issue. I have just about had it with the ongoing problems.
Mine is a 75, 2.0 with original FI. I dropped a valve seat and gave it to my garage to repair the head and replace all the valves. It all went back together and fired and ran but only for a very short time as all the cylinders ran rich and fouled the plugs. So my take on this is that it can't be the injectors as they are not all likely to fail at the same time. Perhaps it is something in the system that makes the injectors fire continuously? So could that be trigger points? If you could give me any ideas as to why all the plugs might foul I will start looking at each one until I nail it. Thanks Guys. Richard (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
catsltd |
May 26 2016, 08:31 PM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
I needed your help before and now we have a new issue. I have just about had it with the ongoing problems. Mine is a 75, 2.0 with original FI. I dropped a valve seat and gave it to my garage to repair the head and replace all the valves. It all went back together and fired and ran but only for a very short time as all the cylinders ran rich and fouled the plugs. So my take on this is that it can't be the injectors as they are not all likely to fail at the same time. Perhaps it is something in the system that makes the injectors fire continuously? So could that be trigger points? If you could give me any ideas as to why all the plugs might foul I will start looking at each one until I nail it. Thanks Guys. Richard (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) My guess its a vacum leak. Head gasket maybe.but for sure something is leaking,or not sealed right. My FI had same problem with fouling plugs,but forgot what caused it. I just got my 1.8L working like a new car,and clutch blew apart. These cars take more patience than anything I have ever done. |
Lo-Fi Version | Time is now: 12th May 2024 - 01:07 PM |
