Oh dear-here we go again!, Running rich |
porschefile2010 |
May 26 2016, 07:49 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
I needed your help before and now we have a new issue. I have just about had it with the ongoing problems.
Mine is a 75, 2.0 with original FI. I dropped a valve seat and gave it to my garage to repair the head and replace all the valves. It all went back together and fired and ran but only for a very short time as all the cylinders ran rich and fouled the plugs. So my take on this is that it can't be the injectors as they are not all likely to fail at the same time. Perhaps it is something in the system that makes the injectors fire continuously? So could that be trigger points? If you could give me any ideas as to why all the plugs might foul I will start looking at each one until I nail it. Thanks Guys. Richard (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
Tom_T |
May 27 2016, 12:42 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Hi Richard,
I just sent you an email on this & the other info. you wanted before. Again for those reading on here, if you've got a shop doing your work for pay who cannot diagnose & fix these issues, then you need a different shop more familiar with 914/411/412/Bus with the 2.0s IMHO! (IMG:style_emoticons/default/dry.gif) I mention the MPS noted above + FPR & ECU + bad rebuilt injectors possibilities, as well as possible problems if that D-jet was used & modified on your prior 2.4 that came on the car. Tom /////// |
Lo-Fi Version | Time is now: 13th May 2024 - 02:31 AM |
