WTB : Early 911 CV axles |
914itis |
May 27 2016, 09:31 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
As I was doing my rear 5 lugs conversion, I noticed that my Cv's wi not fit on the shaft and stubs .
I know this is a long shot here , I also posted on the bird , but this site is home . If anyone you have a set , please let me know . Both left and right . |
bdstone914 |
May 27 2016, 04:40 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
As I was doing my rear 5 lugs conversion, I noticed that my Cv's wi not fit on the shaft and stubs . I know this is a long shot here , I also posted on the bird , but this site is home . If anyone you have a set , please let me know . Both left and right . What CV's do you have? Pre 76? I may have some axles. Bruce |
914itis |
May 27 2016, 05:06 PM
I'll pm you
Catorse |
May 28 2016, 09:29 AM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
I have two brand new early 911 axles since I went with a custom axle. I only needed them for the CV joints but the axles and boots are BRAND NEW. Will sell for $150 per pair.
bdstone914 |
May 28 2016, 02:46 PM
I spoke with Paul and he needs CV's. Only complete axles are available. If anyone has a source for 110mm four bolt CV's please chime in.
mepstein |
May 28 2016, 03:41 PM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Paul - I wasn't sure from the description you needed cv's. I'm sure we have some. PM or text me your address and I'll get some out to you on Tuesday. Mark
Catorse |
May 28 2016, 06:01 PM
Yeah so you buy two new axles, press the CVs off, and now you have four new CVs. That's what I had to do, and that is why I have two axles left over.
914ltd |
May 29 2016, 09:03 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
I'm not sure what you are converting but the 911 axles will not work on a 914 because the length of the axle is shorter than the 914. Machined spacers, modified 914/6 axles or custom axles will be needed. Brad
914itis |
May 29 2016, 09:20 AM
Oh jeez ,, it gets more complicated .
I am using parts from a 70 911 to convert . Everything , hubs , stubs, flange are from 70 911. What's the solution here ? TIA |
Catorse |
May 29 2016, 10:12 AM
Oh jeez ,, it gets more complicated . I am using parts from a 70 911 to convert . Everything , hubs , stubs, flange are from 70 911. What's the solution here ? TIA Easy, you call Eric at PMB and have him order you a set of sway away custom length axles, and then you use all that shit you mentioned above. That's what I did. I also needed CVs, and I am here to tell you they cannot be bought separately unless they are used. I wanted new ones, so I had to buy complete early 911 axles. I then pressed off the CVs, and put them on the sway away units. Sway aways are like $330, new 911 axles are like $500. The rest you have. |
mepstein |
May 29 2016, 10:22 AM
The five lug thread for early 911 drivetrain.
http://www.914world.com/bbs2/index.php?showtopic=91963 |
914itis |
May 29 2016, 10:36 AM
The five lug thread for early 911 drivetrain. http://www.914world.com/bbs2/index.php?showtopic=91963 Thanks |
hencar |
Jun 6 2016, 04:00 PM
Member Group: Members Posts: 73 Joined: 30-May 06 From: Little Rock, Arkansas Member No.: 6,097 |
If you have the 108mm stub axles and the 108mm output shafts at the transmission then buy the 4 bolt 2 stud 911 Axles from PMB and the Sway a way axles. Follow the thread for DIY instructions provided by Eric Shea.
Remove the CVS from the 911 axles and mount them onto the Sway a way. They use a floating setup so it is a little strange but they work great. The 911 axle is too short for the 914. If you don't have the 108mm stub axles and or the output shafts at the transmission. Let me know. I have both setups. Good luck with your project Henry |
Lo-Fi Version | Time is now: 7th May 2024 - 06:14 PM |
