QUOTE(914itis @ May 29 2016, 08:20 AM)
Oh jeez ,, it gets more complicated .
I am using parts from a 70 911 to convert . Everything , hubs , stubs, flange are from 70 911.
What's the solution here ?
TIA
Easy, you call Eric at PMB and have him order you a set of sway away custom length axles, and then you use all that shit you mentioned above. That's what I did. I also needed CVs, and I am here to tell you they cannot be bought separately unless they are used.
I wanted new ones, so I had to buy complete early 911 axles. I then pressed off the CVs, and put them on the sway away units. Sway aways are like $330, new 911 axles are like $500. The rest you have.
