WTB : Early 911 CV axles |
914itis |
May 27 2016, 09:31 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
As I was doing my rear 5 lugs conversion, I noticed that my Cv's wi not fit on the shaft and stubs .
I know this is a long shot here , I also posted on the bird , but this site is home . If anyone you have a set , please let me know . Both left and right . |
hencar |
Jun 6 2016, 04:00 PM
Member Group: Members Posts: 73 Joined: 30-May 06 From: Little Rock, Arkansas Member No.: 6,097 |
If you have the 108mm stub axles and the 108mm output shafts at the transmission then buy the 4 bolt 2 stud 911 Axles from PMB and the Sway a way axles. Follow the thread for DIY instructions provided by Eric Shea.
Remove the CVS from the 911 axles and mount them onto the Sway a way. They use a floating setup so it is a little strange but they work great. The 911 axle is too short for the 914. If you don't have the 108mm stub axles and or the output shafts at the transmission. Let me know. I have both setups. Good luck with your project Henry |
Lo-Fi Version | Time is now: 19th May 2024 - 08:16 AM |
