Does it help, Hot weather driving |
Coondog |
May 31 2016, 09:59 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Getting ready to bring my 914 home. Arizona to Calif. just my luck, this week will see the hottest weather. Need to be on the road by 3am but still 80 degrees.
Question.....Does driving with the engine lid up make any difference in engine temp ?? |
Tom_T |
May 31 2016, 10:13 AM
Getting ready to bring my 914 home. Arizona to Calif. just my luck, this week will see the hottest weather. Need to be on the road by 3am but still 80 degrees. Question.....Does driving with the engine lid up make any difference in engine temp ?? No.... Just carry a spare fan belt, tools to change it & anything else, spare spark plugs, & oil & check level at every stop, & try to park in shade on stops to help cool it. Mine was always very reliable on desert trips to Havasu etc. - especially after I had the fuel pump relocated up front per the Porsche service bulletin after a no start after a stop at the Blythe Denny's, due to the hot restart fuel vapor lock issue. Your `75 already has the factory pump relocation, so you shouldn't experience that problem. You'll find your biggest issue will be the heat on you! Don't be tempted to take the top off for that run, cuz it just makes it hotter IMHO. Open the windows & fan on full! (IMG:style_emoticons/default/smile.gif) Hope to meet you in person if you can make it to Mile Square Park in Fountain Valley on 6/18 9-3 for the PCA OCR Concours, &/or at the Steve McQueen Charity Concours at Boys Republic in Chino on 6/4 8-2. The latter is multi-marque - so bring one of your American classics for display/entry, & the 914 to entor or display on the 18th. Have a fun drive & safe travels! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Coondog |
May 31 2016, 10:45 AM
Thanks Tom, I always removed the rain tray from my past 914s thinking it would help cooling. Oh well !!! Just replaced fan belt, topped off oil and triple checked all fuel lines. Driving from the desert to the desert...... (IMG:style_emoticons/default/WTF.gif)
Fountain Valley show could happen. I will let you know if I can make it. |
michael7810 |
May 31 2016, 11:40 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I left my engine lid open by accident leaving a nigh time car gathering and discovered it completely blocks the back window; and with no right side mirror I was forced to turn left which in my case was a freeway on ramp going away from home. Lessons learned.
BTW: I'm in Phoenix so PM if you need anything. |
May 31 2016, 11:46 AM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I always removed the rain tray from my past 914s thinking it would help cooling. Removing the rain tray might help a bit and it sounds like you're not expecting any rain. It certainly won't make it run hotter. (IMG:style_emoticons/default/shades.gif) |
Chris914n6 |
May 31 2016, 02:23 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
My plan wold be to keep the windows closed, the airflow will dry you out faster.
Cover everything in white towels. The black vinyl will hit 180F in the sun. Wear white clothes that cover you to keep the sun off. Keep a cooler in the car full of ice and water and a wash cloth or 2. Don't drink any sodas of the trip. Good Luck |
May 31 2016, 02:32 PM
Keep a cooler in the car full of ice and water and a wash cloth or 2. I have one of these for my desert roadtrips, works great! Attached image(s) |
May 31 2016, 06:16 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Leaving the engine lid up may help a little bit, but as stated it will block your view out the rear window. It will also bounce up and down, which may get irritating.
If you're worried, you can remove the lid and stash it in the trunk or stand it up in the passenger's seat. If you're very worried, you should probably look into some oil temp and head temp gauges. I managed to survive a trip from SF to Salt Lake City in late June. It was kind of brutal. I did keep the windows down, but I made sure I had plenty of cold water. I had an ice chest that I kept full of water bottles, and had more bottles to go in when I drank some. I also had a washcloth that I would throw into the melted ice in the cooler and then drape around my neck. I do wish it had been a bit larger, like a hand-towel or a dish towel. Ear plugs are necessary, I think. The noise really will wear you down over the course of a few hours. I used ear-buds and played music, but just plain earplugs would probably do as well. I did not feel the need to cover up the dash or steering wheel. I think white towels would make for more windshield reflections than I am comfortable with. Long sleeves or lots of sunscreen are very strongly recommended! --DD |
76-914 |
May 31 2016, 08:40 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Believe it or not, wash out a bottle of spray butter with hot water to flush. Then fill with plain water. They spray an incredibly fine mist that evaporates within a few seconds.
jsh |
May 31 2016, 09:45 PM
Newbie Group: Members Posts: 17 Joined: 11-November 13 From: Chula Vista CA Member No.: 16,631 Region Association: None |
I put a wire between the two parts of the latch so the hatch is about 1/3 up. I think it helps. On my VW beetle I made a prop to keep the lid open about 8 inches at the bottom. I use this because my VW is very original thus no stand offs that many use for extra hot air cooling
Larmo63 |
May 31 2016, 10:25 PM
Just drive fast, use your head and do it.
Gunn1 |
Jun 1 2016, 08:13 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Another way to remedy the issue...
Move to Minnesota! Beautiful scenery, 10,000+ lakes so plenty of spots to jump In and cool off. Just a thought...... |
Coondog |
Jun 1 2016, 09:16 PM
8pm 100 degrees...... (IMG:style_emoticons/default/sad.gif)
Alarm set for 3am Calif bound home by 9am (IMG:style_emoticons/default/smile.gif) Thanks for all the tips... |
Gunn1 |
Jun 2 2016, 11:27 AM
8pm 100 degrees...... (IMG:style_emoticons/default/sad.gif) Alarm set for 3am Calif bound home by 9am (IMG:style_emoticons/default/smile.gif) Thanks for all the tips... There is a apple valley in Minnesota |
Lo-Fi Version | Time is now: 8th May 2024 - 07:41 PM |
