stripped shift linkage cone screw |
ggenovez |
Jun 1 2016, 08:22 PM
Newbie Group: Members Posts: 19 Joined: 8-December 14 From: DFW Member No.: 18,201 Region Association: None |
Hi all.
I've run into some trouble trying to remove my engine. The transmission shift linkage cone screw is severely ceased and the allen nut was rounded. I tried liquid wrench, cutting a slot and using a screw driver, heat, welding a nut (it just fell off every time), beating a torx bit into it and that stripped the rest of it. Any other ideas? |
GaroldShaffer |
Jun 1 2016, 08:43 PM
You bought another 914? Group: Benefactors Posts: 7,622 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
you can try an easy out bit. I have had a few parts cars in the past that I had to drill out the screw.
Mueller |
Jun 1 2016, 09:23 PM
I'd try a left hand drill or easy out...might have to pony up and get some replacement parts if you mess up too badly.
Mikey914 |
Jun 2 2016, 01:05 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Try drilling out with a left hand bit.
EdwardBlume |
Jun 2 2016, 07:47 AM
BTDT - I tried it all and ended up buying a new connector after drilling through it.
gcrotvik |
Jun 2 2016, 08:20 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
brant |
Jun 2 2016, 08:29 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
you guys should send me your ovaled out/destroyed connectors...
I'd pay shipping and put them to good use brant |
Mueller |
Jun 2 2016, 08:42 AM
I've repaired the tapered section with epoxy, you can use a new set screw as the pattern.
TheCabinetmaker |
Jun 2 2016, 10:05 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Hammer in a torx bit the of the first size that won't fit. Use a little heat, and back it out.
ThinAir |
Jun 2 2016, 10:11 AM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I had a similar problem. I used an Easy-Out, but had to drill the cone screw in order to get the right size hole so it would bite. I ended up with the cone piece still in front shirt rod and had to drill that out separately after I slid the coupler off. Fortunately, new cone screws are readily available and I didn't mess up the threads in the coupler.
Lo-Fi Version | Time is now: 20th May 2024 - 01:21 AM |
