Brembo 3#, What spreader part # |
DavidSweden |
Jun 3 2016, 04:25 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Hope someone can help me out.
I have installed some 3" Brembo front brake calipers on my 5 lug conversion. I think they are from an Alfa GTV6 but its been difficult to find a part number I need some brake pad spreaders and pins. Any one got the part numbers so I get the correct parts Thanks (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1464949533.1.jpg) |
lonewolfe |
Jun 3 2016, 05:19 AM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Hope someone can help me out. I have installed some 3" Brembo front brake calipers on my 5 lug conversion. I think they are from an Alfa GTV6 but its been difficult to find a part number I need some brake pad spreaders and pins. Any one got the part numbers so I get the correct parts Thanks (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1464949533.1.jpg) Eric at PMB has them. i believe the pins & clips are the same as ATE's. I'm not sure about the spreader. |
Harpo |
Jun 3 2016, 06:37 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Eric restored mine. I also need hardware & pads.
lonewolfe |
Jun 3 2016, 06:50 PM
Eric restored mine. I also need hardware & pads. I have a set of these too but have not installed them yet. I bought new hard lines, and Porterfield brake pads from Eric. I know he carries the hardware for these as well. He has these brake calipers on his website. He describes them as basically S-Calipers with 3" bolt spacing instead of 3.5" as I recall. The 3" Brembo aluminum calipers came on Alfa Milano's and GTV6 cars. I'm pretty sure they use the same brake pads as Porsche S calipers. |
DavidSweden |
Jun 3 2016, 10:59 PM
Eric restored mine. I also need hardware & pads. I have a set of these too but have not installed them yet. I bought new hard lines, and Porterfield brake pads from Eric. I know he carries the hardware for these as well. He has these brake calipers on his website. He describes them as basically S-Calipers with 3" bolt spacing instead of 3.5" as I recall. The 3" Brembo aluminum calipers came on Alfa Milano's and GTV6 cars. I'm pretty sure they use the same brake pads as Porsche S calipers. Yes thats what I thought and bought some pad spreaders for S calipers. the spreaders were about 10mm to wide and would not go into the caliper |
Lo-Fi Version | Time is now: 9th May 2024 - 03:23 AM |
