Glass bead blasting on valves? |
SLKWrx |
Apr 5 2005, 08:23 AM
Member Group: Members Posts: 318 Joined: 28-September 04 From: Woolwich, NJ Member No.: 2,845 Region Association: North East States |
Until today I had thought that I would need new valves for my 2056 project. My intake valves looked like they had been oddly etched. It wasn't until one of the metal guys that I work with took a look and said it is probably just carbon buildup.
My Question: Can I use Glass Beads as a media blast to clean up the valves? will I ruin them if I do it? Thanks all -- Steve |
SLITS |
Apr 5 2005, 09:22 AM
Glass beads will not remove metal....only deposits....blast away, I do it all the time.
DonTraver |
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
I've glass bead blasted vavles before with no problem. The carbon build-up is not in the wear surface (stem) of the valve. Just go over them lightly until the carbon is gone, ya know. Another way if you're not sure about that is a wire brush on a bench grinder. You can also get some carbon remover and soak them first to soften up the carbon deposits. Be careful with the carbon remover, wear heavy gloves, it'll take your skin off.
Take care, Don |
SLITS |
Apr 5 2005, 10:18 AM
Hi Don,
Have boat and skis...no gernades tho! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
914GT |
Apr 5 2005, 10:20 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
These valves on my old 2.0L have been bead blasted and then moly/thermal coated.
(IMG:http://home.earthlink.net/~docsengine/sitebuildercontent/sitebuilderpictures/pa110010.jpg) |
DonTraver |
Apr 5 2005, 11:28 AM
Dodging gernades on water ski's is what makes it exciting, also tests your vision and reflexes, lol. End of hijack.
SLKWrx |
Apr 5 2005, 11:32 AM
Wow.. alrighty then. Time to get to the media blaster.. Thanks for the advice all.
Lo-Fi Version | Time is now: 21st May 2024 - 09:12 AM |
