Glovebox door removal, How do I get it out? |
DaveO90s4 |
Jun 6 2016, 01:12 AM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
I need to re glue the vinyl to the front of my glovebox flap, and to do it properly and clamp it while the glue dries I want to remove the glovebox 'door' flap.
Have undone the two pivot bolts and the small spring, but for the life of me can't manoeuvre it out of its hole. Had a look underneath the dash with the thought of removing the strap and taking the glove 'box' out and removing the flap out the back, but that looks near on impossible too. I then thought of leaving it in situ, and using double sided tape instead of glue, but I think the thickness of the tape might make the flap foul the top of the fixed dashboard piece as it opens. Suggestions welcome, thanks Dave |
Jun 6 2016, 01:14 AM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Sorry, take out th glove box.
DaveO90s4 |
Jun 6 2016, 01:16 AM
That was a quick reply - thanks. But I can't even see the bolts / nuts at the end of the under-dash glovebox steel strap. Too much in the way....
Is it one of those jobs where I should start by removing one of the back wheels?? (IMG:style_emoticons/default/beerchug.gif) |
Jun 6 2016, 01:21 AM
One nut, drivers side (not you) that hold the strap.
Take that off, the strap is hooked into the passenger side where you can feel it but not see it...so unhook it. Box will basically fall off and down. Then, while whistling the national anthem of Germany, lay on your left leg, head in under th dash....hold your left arm high.........you get the picture... You can see the rest of the project now that the box is gone. |
DaveO90s4 |
Jun 6 2016, 01:58 AM
Thanks (again).
I'll start it on saturday morning, finish it late sunday night with a bit of luck, and go to the physio on monday. Dave |
76-914 |
Jun 6 2016, 07:28 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
So, no one is going to tell him about reconnecting the lovely springs? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif)
cary |
Jun 6 2016, 07:40 AM
Nope ...........
DaveO90s4 |
Jun 6 2016, 05:25 PM
You guys are a laugh a minute!! I was thinking of tying a draw string to the glovebox hook end of the spring. Any better ideas on this mission critical piece of 914 engineering?
Jun 6 2016, 08:51 PM
Nah, you need to figure it out, it's a rite of passage.
Then you can enter your best time to remove and replace the alternator |
DaveO90s4 |
Jun 7 2016, 01:35 AM
OK. This is what I'll do. I will record the time from the moment I start to try to hook on the spring to the moment I am successful - including all elapsed time - and will post the results just for laughs. Then you can all tell me how I should have done it. Meanwhile I'll see if I can find the secret of how to do it. That research time is not included in the doing time (IMG:style_emoticons/default/evilgrin.gif)
falcor75 |
Jun 7 2016, 02:38 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
When do we tell him that most of us never bothered to reattach the spring? (IMG:style_emoticons/default/biggrin.gif)
DaveO90s4 |
Jun 7 2016, 03:47 AM
Too late. Already thought of that. But I'm up for the momentous challenge.
barefoot |
Jun 7 2016, 06:19 AM
Senior Member Group: Members Posts: 1,271 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Too late. Already thought of that. But I'm up for the momentous challenge. Funny you should ask about this now, I've been re-installing glove box in my dash just now. Course i have the dash out due to some wiring snafus under there. I put the OEM spring back on (had one side only) and confirm that it doesn't do anything to hold the door either open or closed. Then I tried modifying another similar spring by shortening it so it retained some tension, still no useful effect. Just snug up the 2 hinge bolts to friction lock the lid. Here's what it looks like back under there: |
Twonicks001 |
Jun 7 2016, 07:53 AM
Newbie Group: Members Posts: 32 Joined: 14-December 15 From: Texas Member No.: 19,458 Region Association: Southwest Region |
I had the same loose material issue. After doing the removal dance I just used a slow drying glue and several large binder paper clips to clamp all along the edge. Dried perfectly and looks like new.
76-914 |
Jun 7 2016, 08:02 AM
Nah, you need to figure it out, it's a rite of passage. Then you can enter your best time to remove and replace the alternator Damn it Rich, you made me blow coffee out my nose with that comment. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) OK. This is what I'll do. I will record the time from the moment I start to try to hook on the spring to the moment I am successful - including all elapsed time - and will post the results just for laughs. Then you can all tell me how I should have done it. Meanwhile I'll see if I can find the secret of how to do it. That research time is not included in the doing time (IMG:style_emoticons/default/evilgrin.gif) Nah, that's not important. We have all of those stats. What we're really interested in is new curse words. I think we are up to 17 new curse words that were borne from those two little springs. (IMG:style_emoticons/default/happy11.gif) |
Jun 7 2016, 10:08 AM
Valy |
Jun 7 2016, 10:21 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I replaced the vinyl without removing the door.
But yes, that spring reattachement is a nice way to spend a full long weekend. |
whitetwinturbo |
Jun 7 2016, 10:20 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Here's how to get the door off. Put this small device under car ..........
DaveO90s4 |
Jun 8 2016, 01:15 AM
Yes, could do that. Not sure about "to assemble simply reverse disassembly" procedures
DaveO90s4 |
Jun 11 2016, 02:25 AM
Time from starting first spring to completing second spring : 8 minutes.
Dave |
Lo-Fi Version | Time is now: 5th May 2024 - 03:36 AM |
