My First Hiccup, finally put this to bed after the 3rd try |
76-914 |
Jun 6 2016, 08:08 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
When we returned from Rt66 '16 I pulled my exhaust system down for a little trimming and noticed water in the left bank muffler! (IMG:style_emoticons/default/WTF.gif) We did drive through a ton of water on that trip. Then when returning from Costco yesterday it acted as if it were starved for fuel when it stumbled during acceleration. The fuel filter was the same one that came on the engine so I ordered another one. When I looked at the filter to check which one I had I noticed the coolant level in the expansion tank/reservoir had dropped. Well, there you are. Head gasket time. Now, I'm wondering if the stumble was due in fact to the head gasket failing? Decisions; should I fix this one which presently has ~ 185K or buy a JDM replacement. After perusing the net I found a few peep's whose JDM experience was less than stellar. Apparently it is a crap shoot as to what you get and the 40-50K avg mileage is (IMG:style_emoticons/default/bs.gif) . So, for about 1K I can pick up another engine and hope I bought a good one or open this one up and hope that is all it needs since it wasn't overheated. What does the the Wasser family think?
EDIT: It's an EZ30D 6cyl |
effutuo101 |
Jun 6 2016, 06:09 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
That sucks. But from what I have read, pretty simple to do.
good luck! My time to get out and play is limited, but happy to help pull the motor/install with you. |
76-914 |
Jun 6 2016, 06:43 PM
That sucks. But from what I have read, pretty simple to do. good luck! My time to get out and play is limited, but happy to help pull the motor/install with you. Haha, I just commented in your post, as well. Thanks for the offer Chris but if you've seen my "roll around" cradle you can see it's pretty simple. That being said, you are more than welcome to come over anytime. I'm in the Temecula/Murrieta area. (IMG:style_emoticons/default/beerchug.gif) Kent |
Lo-Fi Version | Time is now: 19th May 2024 - 12:14 AM |
