My First Hiccup, finally put this to bed after the 3rd try |
76-914 |
Jun 6 2016, 08:08 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
When we returned from Rt66 '16 I pulled my exhaust system down for a little trimming and noticed water in the left bank muffler! (IMG:style_emoticons/default/WTF.gif) We did drive through a ton of water on that trip. Then when returning from Costco yesterday it acted as if it were starved for fuel when it stumbled during acceleration. The fuel filter was the same one that came on the engine so I ordered another one. When I looked at the filter to check which one I had I noticed the coolant level in the expansion tank/reservoir had dropped. Well, there you are. Head gasket time. Now, I'm wondering if the stumble was due in fact to the head gasket failing? Decisions; should I fix this one which presently has ~ 185K or buy a JDM replacement. After perusing the net I found a few peep's whose JDM experience was less than stellar. Apparently it is a crap shoot as to what you get and the 40-50K avg mileage is (IMG:style_emoticons/default/bs.gif) . So, for about 1K I can pick up another engine and hope I bought a good one or open this one up and hope that is all it needs since it wasn't overheated. What does the the Wasser family think?
EDIT: It's an EZ30D 6cyl |
DBCooper |
Jun 17 2016, 11:21 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
See, water = corrosion, just sayin Subaru Effed up......that's the answer. Kent, the delaminated part was the center cylinder? The discolored part on the gasket in the top photo? Any time it overheated? That's the usual cause of failed head gaskets, not pressure, but you usually also get warped heads, so it's a little odd. If so I'd say consider yourself lucky, put it back together with the Cometic gaskets, don't overheat it again and you should be good. If not then maybe there's something specific to that motor, so maybe post the photos in one of the Subaru forums. I don't think many of the folks here have much watercooled experience. |
76-914 |
Jun 18 2016, 09:06 AM
See, water = corrosion, just sayin Subaru Effed up......that's the answer. Kent, the delaminated part was the center cylinder? The discolored part on the gasket in the top photo? Any time it overheated? That's the usual cause of failed head gaskets, not pressure, but you usually also get warped heads, so it's a little odd. If so I'd say consider yourself lucky, put it back together with the Cometic gaskets, don't overheat it again and you should be good. If not then maybe there's something specific to that motor, so maybe post the photos in one of the Subaru forums. I don't think many of the folks here have much watercooled experience. Yes, the center cylinder. Yes, it hit "H" once but just barely. Not enough to boil any water out though. Yeah, I'm going to throw it back together and holler Shit. We'll see what happens. May be a little experimenting here on my part but one can afford to do so with these engines as they are so affordable. I made an offer on another low mileage 3.0 to keep as a spare. This one is nearing 200K. The comments from the peanut gallery are cool. I own one with a 40 yo air cooled engine as well and I actually "do know" the difference between it vs. the Suby 6. I'm sure I don't have to tell you the difference though, Paul. (IMG:style_emoticons/default/beerchug.gif) BTW, I am driving Whitey today when I visit another member. I'm sure that will motivate me to get Kugel on the road again; quickly. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 01:45 AM |
