My First Hiccup, finally put this to bed after the 3rd try |
76-914 |
Jun 6 2016, 08:08 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
When we returned from Rt66 '16 I pulled my exhaust system down for a little trimming and noticed water in the left bank muffler! (IMG:style_emoticons/default/WTF.gif) We did drive through a ton of water on that trip. Then when returning from Costco yesterday it acted as if it were starved for fuel when it stumbled during acceleration. The fuel filter was the same one that came on the engine so I ordered another one. When I looked at the filter to check which one I had I noticed the coolant level in the expansion tank/reservoir had dropped. Well, there you are. Head gasket time. Now, I'm wondering if the stumble was due in fact to the head gasket failing? Decisions; should I fix this one which presently has ~ 185K or buy a JDM replacement. After perusing the net I found a few peep's whose JDM experience was less than stellar. Apparently it is a crap shoot as to what you get and the 40-50K avg mileage is (IMG:style_emoticons/default/bs.gif) . So, for about 1K I can pick up another engine and hope I bought a good one or open this one up and hope that is all it needs since it wasn't overheated. What does the the Wasser family think?
EDIT: It's an EZ30D 6cyl |
Chris H. |
Aug 27 2016, 07:31 PM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Hey mail it to me if you're gonna throw it in the trash. I'll send you a label man (IMG:style_emoticons/default/biggrin.gif) !
I think you got it this time. Maybe the sludge was keeping it sealed up. BTW RE: the towing thread...I was wondering...you think your fuel pressure regulator is OK? I don't know how it's set up on that motor. Mine is on the fuel rail. Did you transfer yours from the other engine? Might be worth checking. Two pumps in a couple months is weird. |
76-914 |
Aug 28 2016, 09:33 AM
Hey mail it to me if you're gonna throw it in the trash. I'll send you a label man (IMG:style_emoticons/default/biggrin.gif) ! I think you got it this time. Maybe the sludge was keeping it sealed up. BTW RE: the towing thread...I was wondering...you think your fuel pressure regulator is OK? I don't know how it's set up on that motor. Mine is on the fuel rail. Did you transfer yours from the other engine? Might be worth checking. Two pumps in a couple months is weird. It's a possibility. I thought I'd check the return line after this one is installed. It shouldn't be passing too much fuel when in use. If it is I'd suspect the regulator. I forgot to mention that I sprung for the "real deal" Three Bond sealant. Yes it is a huge tube but IMHO, well worth it. The difference is obvious when compared to the cheaper Permatex. It flows much better which is a BIG deal if you've ever resealed these cover halves. I'll probably put the rest together today. As soon as I shake the Cobwebs out of my head this AM. I drank a little at Ron's Friends & Family send off. (IMG:style_emoticons/default/drunk.gif) . (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 27th May 2024 - 01:16 AM |
