L-jet idle woes., Any ideas? |
Dave Blackburn |
Jun 19 2003, 10:04 PM
Member Group: Members Posts: 116 Joined: 9-April 03 From: Issaquah, Wa Member No.: 551 |
Hey guy's.
I have my engine installed now, but I can't seem to get the idle right. Before I removed the engine I had it running absolutely perfect. It would start on the first crank every time, idle @ 1600rpm for a couple of minutes and then idle peasefully @ 850rpm all day. The problem now is when I start it cold it will start right away and idle good @ 1700 rpm. Once the AAV starts to close the engine will stumble and when fully closed it will die completely. I have adjusted the throttle body idle adjustment and the air bypass valve for hours with no results. If the engine speed drops below 1300 rpm it will die. I have a solid 33 PSI of fuel pressure at all rpm's, no vacume leaks and it doesn't seem to be running rich/lean. I did a compression test and all the cylinders are @ 110 PSI with one @ about 95 PSI. I also did a leakdow test and all the cylinders were excelent @ about 5% leakage from ring gaps. My ignition system is a MSD 6A with blaster coil and electronic point replacement and seems to be working good, it (engine) was also just rebuilt under 100 miles ago. I have tested the head temp sensor and the cold start valve is bypassed right now. Anyone have any ideas? I have checked pretty much everything. I am kinda pissed because it was running so well before I removed it to clean it up and paint it (no mechanical). Please give me any and all suggestions. I would really like it to run well again. Thanks, Dave (IMG:style_emoticons/default/beerchug.gif) |
Jeff Krieger |
Jun 19 2003, 10:13 PM
Unregistered |
ChrisReale |
Jun 19 2003, 10:15 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Go through everything once more. Trace all vacuum hoses and make sure they go where they should. If you didn't alter anything mechanically, it has to be something you are overlooking (IMG:style_emoticons/default/ph34r.gif)
ChrisReale |
Jun 19 2003, 10:21 PM
Great link! I know squat about L-Jet. Thanks
Lo-Fi Version | Time is now: 3rd June 2024 - 01:34 PM |
