Need some help on a bolt size, Rear sway bar bolt- |
ottox914 |
Jun 10 2016, 04:49 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I have a weltmeister adjustable sway bar on the rear of the 914. Over the course of packing up my life and moving, I have lost pair of bolts. These are the bolts that go thru the drop link, and into the huge bolt that goes thru the shock and into the trailing arm.
Anyone know the correct size bolt to go back in there? Got an autox this weekend, got the motor back in last week, and would sure like to go scare some cones. Thanks- |
jcd914 |
Jun 11 2016, 12:35 AM
I have a weltmeister adjustable sway bar on the rear of the 914. Over the course of packing up my life and moving, I have lost pair of bolts. These are the bolts that go thru the drop link, and into the huge bolt that goes thru the shock and into the trailing arm. Anyone know the correct size bolt to go back in there? Got an autox this weekend, got the motor back in last week, and would sure like to go scare some cones. Thanks- IIRC they are 3/8 NF, Ace hardware would probably have them. This just from memory though, nothing here to verify with. Jim |
siverson |
Jun 11 2016, 12:47 AM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Not 3/8.
Here you go: http://bfy.tw/6DNo (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/piratenanner.gif) -Steve |
Harpo |
Jun 11 2016, 11:33 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I don't believe he is referring to the M18 bolt. It sounds like he is threading in to the M18 shock bolt. Obviously a photo would help
David |
ottox914 |
Aug 24 2016, 02:46 PM
Bolt is a 5/16 fine thread. Here's where it goes and what goes there.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 10th May 2024 - 12:02 PM |
