Start up new 1.7 L engine, Best way(s) to start a complete rebuild |
pgollender |
Jun 15 2016, 09:36 AM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
1970 1.7 L, in nearly six years in restoration, I've got my engine ready to start on the test stand.
I have the fuel rails primed. Electrical has checked out OK. Just wanted to get group thoughts on what they do ? Turn engine over to prime oil pump or just start it. How long to run it initially, and how or should I vary engine speed much , and to what extent ( rpms)? Also do I change oil immediately after "break-in". What do I need to be concerned about ? Besides everything !!! Engine is nearly stock (slightly higher compression pistons) with original FI. |
stugray |
Jun 15 2016, 09:42 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Prime first. Do not fill oil filter. I use a mechanical oil pressure gauge. If pump is new you should be able to get above 30psi. crank for a few seconds and let the starter cool. Once you have oil pressure fire it up and follow cam manufacturer suggested break in procedure.
TheCabinetmaker |
Jun 15 2016, 10:44 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Did you install a new cam?
pgollender |
Jun 15 2016, 12:27 PM
stugray |
Jun 15 2016, 02:01 PM
My flaps has many different brands. The exact one I used is for an accusump.
rgalla9146 |
Jun 15 2016, 07:50 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
A gauge is an excellent suggestion.
But .......you can get by with just your oil pressure switch. Attach a test light lead to power (+12V side of coil) and the other lead to the spade of the OP switch. Remove spark plugs. Crank engine for 15 seconds at a time until the test light goes out. Reinstall plugs. Start it up ! ......listen ! |
Lo-Fi Version | Time is now: 10th June 2024 - 12:03 AM |
