New GB - Heater cables - CORRECT LENGTH - 70-74, YOU NEED THIS!, These will be $24 (+free nipples) for the GB List is over $38 and mine fit |
Mikey914 |
Jun 15 2016, 10:42 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Again, I've been asked to make correct length heater cables. Apparently the ones on the market are a little too short. These have to be exactly the correct length otherwise they don't reach, and if they are too long the bind up in the flapper arm assembly and will not allow full travel of the flapper, making your heat on not fully on when selected.
These will be nylon coated cables pre-bent for the install at the lever. I've also included 2 free heater cable nipples to seal up the tubes while you are there. So, who's interested? These will be ready in about a week. And who can resist free nipples? Making the 70-74, and the 75-75 version Attached thumbnail(s) Attached image(s) |
banananose914 |
Jun 15 2016, 10:53 AM
Member Group: Members Posts: 235 Joined: 20-November 13 From: california Member No.: 16,681 Region Association: None |
I am in. This is another thing to add to my lengthy 914rubber list
barefoot |
Jun 15 2016, 12:20 PM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I'm in
can't seem to find anyone parting one out that has any Barefoot |
TX914 |
Jun 16 2016, 06:14 AM
Alan-B Group: Members Posts: 167 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
Interested. But for me they really must fit my 76.
dlee6204 |
Jun 16 2016, 06:59 AM
IN. Just broke mine the other day trying to remove it.
76-914 |
Jun 16 2016, 08:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
One of the few things I won't be buying from you Mark! (IMG:style_emoticons/default/rolleyes.gif)
Jun 16 2016, 08:35 AM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I need one
bdstone914 |
Jun 16 2016, 08:38 AM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
There are three different part numbers for the heater cables.
91442407500 914-6 PCG42407501 1970-1974 914 91442407503 1975-1976 914 Are you making all three ? I am not aware of aftermarket suppliers of this part. I did buy a new Porsche one. I may have got the wring part number as the length of each side were wrong. Rebent it to be correct for one side and had to put some zig zags on the other side to take up the extra length. Also the Porsche one did not have the plastic coating like the original one. Are yours going to have the coating ? Bruce |
Jun 16 2016, 08:58 AM
The last one I bought did not have the plastic coating. I liberally coated the cable with water proof grease. It would be nice to have a real coated cable.
Mikey914 |
Jun 16 2016, 09:40 AM
I have the sample which I will be having fit shortly. The OEM one in the picture has a thin coating you can see it if you look closely at the picture. Metal on metal in the tubes can never be a good thing. Main reason I wanted to use coated.
As far as the 3 different cable numbers. I can make these at any length as we actually make these, so I'd be interested to send a few out to get confirmation. My car that we will be fitting is a 75, so 75-76 will be covered. Anyone have a 6 cable for reference? Also looking for a 74 or earlier, and we will make them all correctly. |
76-914 |
Jun 16 2016, 09:45 AM
I have the sample which I will be having fit shortly. The OEM one in the picture has a thin coating you can see it if you look closely at the picture. Metal on metal in the tubes can never be a good thing. Main reason I wanted to use coated. As far as the 3 different cable numbers. I can make these at any length as we actually make these, so I'd be interested to send a few out to get confirmation. My car that we will be fitting is a 75, so 75-76 will be covered. Anyone have a 6 cable for reference? Also looking for a 74 or earlier, and we will make them all correctly. Mark, the one OEM one in the pic is off a '73. |
Mikey914 |
Jun 16 2016, 10:28 AM
That's good, because it it is, I have the one from my 75 and I would have the 2 parts to make these.
How can you tell? Looks like an appearance group lever, but that could be later. |
bdstone914 |
Jun 16 2016, 12:51 PM
That's good, because it it is, I have the one from my 75 and I would have the 2 parts to make these. How can you tell? Looks like an appearance group lever, but that could be later. The difference in the cables is the length and the lever pictured is non console type. |
Rob-O |
Jun 16 2016, 01:29 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I'll take one for a '74.
76-914 |
Jun 16 2016, 06:47 PM
That's good, because it it is, I have the one from my 75 and I would have the 2 parts to make these. How can you tell? Looks like an appearance group lever, but that could be later. Mark, I assume it is because it came off my '73 after it decided it liked H2O more than O2. (IMG:style_emoticons/default/biggrin.gif) |
rjames |
Jun 16 2016, 11:43 PM
I'm made of metal Group: Members Posts: 3,928 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Is the difference in length from early to late cars because a different flapper box was used in the later cars?
Valy |
Jun 17 2016, 12:00 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
One 74 please
Mikey914 |
Jun 17 2016, 01:13 AM
That's good, because it it is, I have the one from my 75 and I would have the 2 parts to make these. How can you tell? Looks like an appearance group lever, but that could be later. Mark, I assume it is because it came off my '73 after it decided it liked H2O more than O2. (IMG:style_emoticons/default/biggrin.gif) Duhh! I forgot...... Thought there was some magic way that you could tell from the picture because I was stumped. |
Mikey914 |
Jul 14 2016, 12:30 AM
1st one (early) sent out for test fitting today. Hopefully, an evaluation of it will be this weekend. Should have Friday (ish). Went out priority mail.
I think we have it spot on, but lets see what the results are. We did make these with nylon coated wires. The OEM were also coated, it was slightly thinner, but not a raw steel cable rubbing inside the tube like the current one (that didn't fit). I could cut my price in half if I used the less expensive cable, but do you really want steel rubbing on steel in the enter tunnel? Ours will at least provide a barrier. |
raynekat |
Jul 14 2016, 12:59 AM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I'm in...
Lo-Fi Version | Time is now: 11th May 2024 - 04:36 PM |
