New GB - Heater cables - CORRECT LENGTH - 70-74, YOU NEED THIS!, These will be $24 (+free nipples) for the GB List is over $38 and mine fit |
gcrotvik |
Jul 14 2016, 07:45 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
In for 2 sets!
walterolin |
Jul 14 2016, 08:21 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
One set, 1970-4
sbsix |
Jul 14 2016, 08:58 AM
only the lead dog enjoys a change in scenery... Group: Members Posts: 451 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
Mark I need one for a 914-6. Has anyone come forward with a template yet?
Mikey914 |
Jul 14 2016, 10:21 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
sbsix |
Jul 14 2016, 03:29 PM
Sent you a PM. I'll pull out the new one I have and measure it and let you know.
sbsix |
Jul 15 2016, 12:22 PM
Pictures with measurements from a new cable I have. Really not sure if it is actually one that fits a 914-6. There is a little slack in the cable, so the actual length is slightly more than shown.
I'll take the cable off of my six this weekend and post the results on this thread. Attached image(s) |
Mikey914 |
Jul 15 2016, 03:21 PM
Thanks we will be ready to start production this next week.
Mark |
ovation919 |
Jul 15 2016, 03:54 PM
Newbie Group: Members Posts: 11 Joined: 29-August 14 From: Los Altos Member No.: 17,838 Region Association: Northern California |
I am interested in the 1974 version.
mapguy |
Jul 15 2016, 05:47 PM
Freelance Generalist Group: Members Posts: 90 Joined: 31-January 14 From: Inland Empire, CA Member No.: 16,945 Region Association: Southern California |
Need 2 for a '74.
sbsix |
Jul 17 2016, 06:37 PM
The picture of the length of the original heater cable from my 914-6 is attached. I sent this on to Mark.
Mikey914 |
Jul 18 2016, 03:12 PM
We will be starting to assemble these later this week
TX914 |
Aug 17 2016, 09:01 AM
Alan-B Group: Members Posts: 168 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
Mark,
How did the cable you made for your 75 work out? Does it have back-dated exhaust? What are the lengths of the driver & passenger side? I’m interested in a new cable for my ’76 which has back-dated exhaust (SSI exchangers and J tubes) and a NOS passenger flapper box. I read from another post that an early cable (70-74, 38 x 40?) should be used for back-dated exhaust. However I am using a cable that measures 38 ¾ (say 39) x 41 with a piece clamped onto the long (passenger) side to make it 43”. That doesn’t seem to match any length previously discussed. Interested to know what lengths others with back-dated exhaust are using before I order one. This is some weird business as I have 3 old cables that measure 38 x 40 ¼ (70-74), 39 x 41 ¾ and 38 ½ x 41 (with some small error due to measuring old cables with bends). If late model cable is reportedly shorter that early, and /6 shorter still, what application is a 38+ x 41+ for? Hope I'm not confusing things further... |
80cap |
Aug 17 2016, 10:55 AM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
I don't know how I missed this thread! I just bought a 70 thru 74 cable from Stoddard's.
I was told it is longer than my 76 cable but you can make it work by twisting the wire at the control handle. Is this true? Thanks Brian |
Mikey914 |
Aug 17 2016, 03:57 PM
I'm sure you could twist it, but will it become unraveled over time? Best bet is to cut and braze to correct legnth.
These are actually just comming into production today as we changed the material due to some feedback on the 1st one we sent out. the cable was not stout enough to not kink when it was pushed through the tunnel. We now have the galvanized wire like brand X and offer an option for a coated cable. Pics to follow tomorrow. Cables fit fine on my 75, and using a known good early. the dimmensions fit on the earlys just went to a better wire. So anyone who's interested we will start sending the codes out tomorrow to all that have resopnded on the thread. -Mark |
Mikey914 |
Aug 17 2016, 04:39 PM
You will need to bump the thread to get the code, so if you want to be included Now's the time.
TX914 |
Aug 17 2016, 05:02 PM
I'm sure you could twist it, but will it become unraveled over time? Best bet is to cut and braze to correct legnth. These are actually just comming into production today as we changed the material due to some feedback on the 1st one we sent out. the cable was not stout enough to not kink when it was pushed through the tunnel. We now have the galvanized wire like brand X and offer an option for a coated cable. Pics to follow tomorrow. Cables fit fine on my 75, and using a known good early. the dimmensions fit on the earlys just went to a better wire. So anyone who's interested we will start sending the codes out tomorrow to all that have resopnded on the thread. -Mark Mark, Is your 75 stock exhaust or back-dated? Any ideas on lengths for 76 with back-dated exhaust? Thanks. |
Mikey914 |
Aug 17 2016, 05:27 PM
I'm sure you could twist it, but will it become unraveled over time? Best bet is to cut and braze to correct legnth. These are actually just comming into production today as we changed the material due to some feedback on the 1st one we sent out. the cable was not stout enough to not kink when it was pushed through the tunnel. We now have the galvanized wire like brand X and offer an option for a coated cable. Pics to follow tomorrow. Cables fit fine on my 75, and using a known good early. the dimmensions fit on the earlys just went to a better wire. So anyone who's interested we will start sending the codes out tomorrow to all that have resopnded on the thread. -Mark Mark, Is your 75 stock exhaust or back-dated? Any ideas on lengths for 76 with back-dated exhaust? Thanks. Mine is not backdated, it is longer. If you know your lengths, I can make sure you get the correct one. I suspect yours may be the shorter one. |
Aug 17 2016, 05:55 PM
914-6 GT in waiting Group: Members Posts: 19,281 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I want an early coated one. Thanks
Mikey914 |
Aug 17 2016, 09:53 PM
We will be making the
914/6 version Early - 70-74 and Late - 75-76 We will be making 2 versions - The bare cable like others that is a few bucks less, as well as the better product with the coated cables to not wear in the tunnel. |
ThinAir |
Aug 17 2016, 11:29 PM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I'm in for the coated ones. 1973 4 cylinder with center console. |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:16 AM |
