| advtracing |
Jun 15 2016, 08:53 PM
Member ![]() ![]() Group: Members Posts: 73 Joined: 27-September 09 From: New Zealand Member No.: 10,853 Region Association: None |
hiya
couple of tec questions - temp gauge doesn't want to work - is it normally the sensor on the engine and if so best pace to buy or gauge needs repair from peoples experience - did the 75 model do away from plastic fuel lines in the tunnel or still had them which means i need to replace them - warning buzzers for door open / key in ignition - are they available ? mine sound pretty sick ( like im sticking a pin in a frog ) cheers in advance |
| MarkV |
Jun 15 2016, 09:18 PM
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
- I think the gauge itself is pretty reliable. I would start by making sure the wiring has continuity. Chances are it's the sending unit on the engine.
- Pretty sure they all came with plastic fuel lines. Unless you got lucky and someone has changed them, chances are they are still plastic. Easy enough to look under the car where they come out by the shifter linkage. The plasic is kind of an opaque yelllow/orange color. - I thought I was the only one that still had a working key buzzer. That's what they sound like.... It grows on you after a while. |
| Mark Henry |
Jun 15 2016, 09:38 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
The plastic lines are fine, they are actually nylon. What fails are the old hoses, improper hose clamps and no through the body grommets. Only use proper correct size FI clamps, do not use the common worm screw hose clamps.
Although if welding has been done close to them, do not have the proper through body grommets, or they have been twisted due to a stuck on fuel hose then they are suspect and should be replaced. Even steel lines must have the proper grommets, without them the body metal will saw right through them. I know some will disagree, but if the capt'n was still with us he would agree with this. |
| bdstone914 |
Jun 15 2016, 10:43 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,264 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
75-76 cars had the fuel pump up front and they went with a black plastic material that was tougher as the feed line was now pressurized as opposed to the earlier cars with fuel pump in the rear sucking fuel through it. The area where lines that see the most deteriorating are where they exit the firewall and are exposed to more heat. SS line kits are available and are safer. The cost about $100 in the states but shipping to NZ will be pricy.
| advtracing |
Jun 16 2016, 01:59 PM
cheers guys , everything advised in a nut shell. i get alot of parts in from the usa for my company so no issue getting some ss lines . the engine and box need to come out anyway for detailing so may as well do the lines at the same time
Lo-Fi Version | Time is now: 3rd March 2026 - 07:13 PM |
