Cylinder Head Temperature Sender location? |
dgraves |
Jun 18 2016, 04:35 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
I'm a new owner of a 1974 2.0. Does anyone have a photo of where the Cylinder Head Temperature sending unit is located on the engine? I have a center console gauge that isn't working and the gauge seems to be fine.
Thanks, Dan. |
Jun 18 2016, 04:38 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The gauge is oil temp . Bottom of motor, taco plate with wire coming out.
If real CHT gauge it's aftermarket so the sensor will be on the other end of the wire plugged into the gauge with no stock location. The stock cht sensor is passenger side rear of motor, just behind the intake manifold bolt on the rear you will see the wire coming out of the head tin. |
dgraves |
Jun 18 2016, 04:47 PM
Thanks, got it. It is an aftermarket CHT.
The gauge is oil temp . Bottom of motor, taco plate with wire coming out. If real CHT gauge it's aftermarket so the sensor will be on the other end of the wire plugged into the gauge with no stock location. The stock cht sensor is passenger side rear of motor, just behind the intake manifold bolt on the rear you will see the wire coming out of the head tin. |
pete000 |
Jun 18 2016, 05:03 PM
Usually it is a sensor ring around one of the spark plugs.
wndsnd |
Jun 18 2016, 05:36 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Look at Cylinder 3 first.
Mark Henry |
Jun 19 2016, 07:16 AM
Cut off the plug crush washer and replace it with the sender.
2.0 heads are a bit of an clearance issue, but will work if you bend the ring close to plug. On new builds I notch for the sender. |
MarkV |
Jun 19 2016, 08:13 AM
If it's a VDO brand it looks like this. It is made to replace the crush washer under one of the spark plugs. It is usually installed on the #3 plug because that cylinder is known to run the hottest. The wire to the sender is not normal vinyl covered wire it has a braided kind of stiff covering. Where the wire attaches to the circular part of the sender it has to be bent to clear the head.
RolinkHaus |
Oct 6 2018, 04:10 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Update: Installed cylinder head temp sensor, new plugs, wires, cap / rotor. Still sweating fuel from cold start valve, which tested ok and has new gaskets.
Thinking of chucking the whole fuel injection, going to carbs. |
Oct 6 2018, 06:06 PM
Don't do that, you'll regret it at some point.
You can remove the hose that goes to the CSV. Cap the fuel rail port that this hose comes from with a bolt of the appropriate size, or use the hose to semi-permanently mount a fuel pressure gauge in the engine bay. Or replace the CSV; it's not exactly that expensive... --DD |
Oct 6 2018, 09:27 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Update: Installed cylinder head temp sensor, new plugs, wires, cap / rotor. Still sweating fuel from cold start valve, which tested ok and has new gaskets. Thinking of chucking the whole fuel injection, going to carbs. Don't be the next DAPO, just don't ... (IMG:style_emoticons/default/dry.gif) |
mct |
Oct 8 2018, 03:01 AM
Newbie Group: Members Posts: 7 Joined: 28-September 16 From: Heidelberg, Germany Member No.: 20,441 Region Association: Germany |
Update: Installed cylinder head temp sensor, new plugs, wires, cap / rotor. Still sweating fuel from cold start valve, which tested ok and has new gaskets. Thinking of chucking the whole fuel injection, going to carbs. Don't be the next DAPO, just don't ... (IMG:style_emoticons/default/dry.gif) DAPO? My acronym-solving capabilities are low ATM. |
Porschef |
Oct 8 2018, 03:39 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Update: Installed cylinder head temp sensor, new plugs, wires, cap / rotor. Still sweating fuel from cold start valve, which tested ok and has new gaskets. Thinking of chucking the whole fuel injection, going to carbs. Don't be the next DAPO, just don't ... (IMG:style_emoticons/default/dry.gif) DAPO? My acronym-solving capabilities are low ATM. Dumb Ass Prior/Previous Owner. Work the bugs out of the FI, it's well worth it. |
Oct 8 2018, 11:16 AM
Work the bugs out of the FI, it's well worth it. (IMG:style_emoticons/default/agree.gif) The FI can be a bit intimidating at first but i can assure you, once you got it sorted you'll be glad you did. When i had my 1.7L D-jet, it took me several weeks to get all the bugs sorted out from many years of neglect, but once it was done, the engine ran exceptionally smooth. Plus, you don't have to worry about elevation. No matter how high (or low) you go, it always starts with the first turn of the key. (IMG:style_emoticons/default/driving.gif) |
Nogoodwithusernames |
Oct 8 2018, 02:32 PM
Member Group: Members Posts: 235 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Work the bugs out of the FI, it's well worth it. (IMG:style_emoticons/default/agree.gif) The FI can be a bit intimidating at first but i can assure you, once you got it sorted you'll be glad you did. When i had my 1.7L D-jet, it took me several weeks to get all the bugs sorted out from many years of neglect, but once it was done, the engine ran exceptionally smooth. Plus, you don't have to worry about elevation. No matter how high (or low) you go, it always starts with the first turn of the key. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) D-jet may seem pretty complicated at first but I really like it. I put aftermarket injection in my squareback but I want to put the stock D-jet back on when I rebuild the original motor. It's a nice system to drive. |
Lo-Fi Version | Time is now: 26th April 2024 - 09:56 AM |
