Cylinder Head Temperature Sender location? |
dgraves |
Jun 18 2016, 04:35 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
I'm a new owner of a 1974 2.0. Does anyone have a photo of where the Cylinder Head Temperature sending unit is located on the engine? I have a center console gauge that isn't working and the gauge seems to be fine.
Thanks, Dan. |
r_towle |
Jun 18 2016, 04:38 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The gauge is oil temp . Bottom of motor, taco plate with wire coming out.
If real CHT gauge it's aftermarket so the sensor will be on the other end of the wire plugged into the gauge with no stock location. The stock cht sensor is passenger side rear of motor, just behind the intake manifold bolt on the rear you will see the wire coming out of the head tin. |
dgraves |
Jun 18 2016, 04:47 PM
Thanks, got it. It is an aftermarket CHT.
The gauge is oil temp . Bottom of motor, taco plate with wire coming out. If real CHT gauge it's aftermarket so the sensor will be on the other end of the wire plugged into the gauge with no stock location. The stock cht sensor is passenger side rear of motor, just behind the intake manifold bolt on the rear you will see the wire coming out of the head tin. |
Lo-Fi Version | Time is now: 27th May 2024 - 06:38 PM |
