Cylinder Head Temperature Sender location? |
dgraves |
Jun 18 2016, 04:35 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
I'm a new owner of a 1974 2.0. Does anyone have a photo of where the Cylinder Head Temperature sending unit is located on the engine? I have a center console gauge that isn't working and the gauge seems to be fine.
Thanks, Dan. |
MarkV |
Jun 19 2016, 08:13 AM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
If it's a VDO brand it looks like this. It is made to replace the crush washer under one of the spark plugs. It is usually installed on the #3 plug because that cylinder is known to run the hottest. The wire to the sender is not normal vinyl covered wire it has a braided kind of stiff covering. Where the wire attaches to the circular part of the sender it has to be bent to clear the head.
Lo-Fi Version | Time is now: 27th May 2024 - 09:28 PM |
