Help! |
Help! |
pacman |
Jun 23 2016, 09:14 PM
Newbie Group: Members Posts: 29 Joined: 5-March 16 From: Bend Member No.: 19,732 Region Association: Pacific Northwest |
Hey guys problem here, i went to change out my speedometer drive and it is frozen into the aluminumn shaft inside the trans. I have tried everything I can to free it up with no luck. Any ideas?
Attached thumbnail(s) |
Jeffs9146 |
Jun 23 2016, 09:44 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
PB Blaster over night then use a large pair of channel lock pliers to gently turn it back and forth. Make sure you have removed the bolt that is holding it in!!
bdstone914 |
Jun 23 2016, 09:54 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hey guys problem here, i went to change out my speedometer drive and it is frozen into the aluminumn shaft inside the trans. I have tried everything I can to free it up with no luck. Any ideas? I can sell you one of 914Rubbers new improved ones with two o-rings for $60 or a used one for $15 shipped. Would have been easier to break that nut loos while it was still in the trans where it is held in place by the bolt. |
pacman |
Jun 24 2016, 12:09 AM
Hey guys problem here, i went to change out my speedometer drive and it is frozen into the aluminumn shaft inside the trans. I have tried everything I can to free it up with no luck. Any ideas? I can sell you one of 914Rubbers new improved ones with two o-rings for $60 or a used one for $15 shipped. Would have been easier to break that nut loos while it was still in the trans where it is held in place by the bolt. I appreciate the offer! Might end up taking you up on that if i cannot get it unfrozen. I tried it in the tranny but because of a stupid mistake cracked a little bit of the case around the thread so cant do that because of risk /: |
pacman |
Jun 24 2016, 12:10 AM
r_towle |
Jun 24 2016, 12:28 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Get a gallon of carb cleaner and dunk it for about ten minutes.
Jeffs9146 |
Jun 24 2016, 11:17 AM
pacman |
Jun 25 2016, 11:14 PM
Thanks guys! Ended up getting it free with a shop and a little heat. Hope to throw it back together soon
Lo-Fi Version | Time is now: 6th May 2024 - 03:25 AM |
