What size bolt pattern are my stock rims, and offset |
Dr. Roger |
Apr 7 2005, 03:41 PM
I'm upgrading the stock steel rims on my '74 914.
I will purchase alloy's and have found some 4x100 and the offset is either 40 or 45. Mounted tire's are Toyo proxies, 205-40-16's. Does the 914 have 4X100 spacing and is 40 or 45mm appropriate for a mildly flared teener. I do want to flare her a little bit... (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
riverman |
Apr 7 2005, 03:53 PM
Learn As I Go Group: Members Posts: 449 Joined: 18-January 05 From: Kitchener, ON Member No.: 3,466 |
4X130mm bolt pattern with a 47mm offset.
Aaron Cox |
stock is 4 x 130
say hello to machine work... |
Dr. Roger |
Apr 7 2005, 04:04 PM
So if I want to do about a 3" flair on all 4 corners what woud the maximum allowable size be?
I do want to go low profile w/larger rims (shorter side walls) (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) I've seen 17's on a stock fendered fourteen and it looked sick! (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) but I have no idea about width and offset... Wider is better (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
phantom914 |
Apr 7 2005, 04:09 PM
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
If you are going to go through the trouble of machining because you just don't like the rims available in 4x130, a 4x4.5" pattern would be better. With a 4x100 pattern, the holes will break into the center circle of the rear brake "hat".
I know that in 17x7 wheels, a good offset is 35mm. Andrew |
Mueller |
Apr 7 2005, 04:15 PM
if 7" rims fit stock fenders, then figure with flares, you can mount 8's and 9's with no problem
I'm pretty sure you can order the Revolution wheels in custom offsets as well for flared cars, not sure how wide they make them tho.... |
Dr. Roger |
Apr 7 2005, 04:55 PM
Revolutions for 1 Grand. Hmmm, I need a second job.
I'm looking for those adaptors to convert 4X130's into the popular 4X100. Anyone happen to have some taking up space in the back corner of their garage?? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Dr. Roger |
Apr 7 2005, 04:57 PM
Nevermind. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
http://www.wheeladapter.com/ Next to the swedish bikini team's website, 914club is thee best!! |
914werke |
Apr 7 2005, 05:06 PM
"I got blisters on me fingers" Group: Members Posts: 10,037 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
BTW the offest on the steelie's is 40 (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Mueller |
Apr 7 2005, 05:21 PM
V8+flares=???
that size you posted above is silly small and would be a waste in my opinion... |
Lo-Fi Version | Time is now: 3rd May 2024 - 09:57 PM |
