FS: GROUP BUY 914-6 Single Motor Mount |
maddog |
Jun 25 2016, 09:15 AM
Member Group: Members Posts: 200 Joined: 19-May 03 From: Grand Rapids Michigan Member No.: 710 Region Association: None |
914-6 OEM replica motor mount designed by Original Customs and manufactured by Maddogs Motor Sports. This mount will fit up to the 3.2 liter flat six and works with early and late cars. BE AWARE that the mount uses the WEVO 911 Sport mount that is sold separately. The retail price on my website is $350, I have 10 available so here is the price breakdown:
5 buyers $300 shipped here is the group buy status so far: 1. Colingreene 2. Flyer86d 3. Mastercylinder 4. Raynekat 5. 914outlaw 6. Mikey914 this group buy will close this Friday August 19 for the $300 price. Those that are on the list so far pm me your paypal emails and I will paypal invoice you. These are ready to ship so as soon as I receive payment they will ship UPS ground. This wiring is on a 75/76 chassis. 70-74 cars will route MUCH better. The hole in the shelf was moved towards the center of the car in the late bodies. |
flyer86d |
Jun 29 2016, 06:04 PM
Member Group: Members Posts: 425 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Can the engine mount portion be used with a stock -6 chassis mount? Reason, I would like a seperate engine mount for the hot rod motor and keep the stock with the original.
Charlie |
maddog |
Jun 30 2016, 05:57 AM
Charlie, I believe it can, LukeM is using the WEVO mount and plate in place of his stock rubber mount and had to put a 6mm shim because the wevo is shorter than the stock one so I think you would be ok? Maybe Mark D can confirm this?
Can the engine mount portion be used with a stock -6 chassis mount? Reason, I would like a seperate engine mount for the hot rod motor and keep the stock with the original. Charlie |
Luke M |
Jun 30 2016, 05:17 PM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
[quote name='maddog' date='Jun 30 2016, 04:57 AM' post='2365813']
Charlie, I believe it can, LukeM is using the WEVO mount and plate in place of his stock rubber mount and had to put a 6mm shim because the wevo is shorter than the stock one so I think you would be ok? Maybe Mark D can confirm this? [quote name='flyer86d' post='2365659' date='Jun 29 2016, 04:04 PM'] Can the engine mount portion be used with a stock -6 chassis mount? Reason, I would like a seperate engine mount for the hot rod motor and keep the stock with the original. Charlie You will need a 6 mm spacer if you are planning on using a Wevo mount/adapter plate with a factory 914-6 firewall and engine mount. I purchased the Wevo mount and adapter plate from Dave/Mark. I noticed right away that there was a height difference between the factory rubber mount and the Wevo. I measured the two side by side and the Wevo was 6 mm shorter then the factory 6 part. I plan on making up a 6 mm spacer that would go between the lower side of the Wevo mount and the top of the factory 6 engine mount. That should fix the height problem. I do not know if Mark added the 6 mm difference on his engine side mount? That would be a question that he would need to answer. Hope this helps out the factory 6 guys looking to replace a worn out/damaged rubber engine mount. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:45 PM |
