WTB - console bracket nut, the weird rubber compression one in the dash bottom |
iankarr |
Jun 26 2016, 04:50 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
When reinstalling my center console bracket to the dash bottom, I apparently pushed the rubber grommet which contains the securing nut up into the dash (and into oblivion). Does anyone have one I can buy? Or know where to purchase? Thanks! |
bdstone914 |
Jun 26 2016, 05:52 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi Guys, When reinstalling my center console bracket to the dash bottom, I apparently pushed the rubber grommet which contains the securing nut up into the dash (and into oblivion). Does anyone have one I can buy? Or know where to purchase? Thanks! Maybe you mean the cage nut that is a square nut in a metal cage that clips into the dash frame? If so it should be there. |
iankarr |
Jun 26 2016, 10:21 PM
Thanks for the response. It's not a cage nut that holds the console bracket in. At least on my car it's not. What I have looks like a short rubber grommet with a nut built-in on the end. It gets pushed up into the hole in the dash, and as the screw tightens into the nut, it compresses the rubber part in front of it, anchoring it in a somewhat flexible way to the dash. There are two, but I lost one!
GaroldShaffer |
Jun 27 2016, 05:26 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Thanks for the response. It's not a cage nut that holds the console bracket in. At least on my car it's not. What I have looks like a short rubber grommet with a nut built-in on the end. It gets pushed up into the hole in the dash, and as the screw tightens into the nut, it compresses the rubber part in front of it, anchoring it in a somewhat flexible way to the dash. There are two, but I lost one! I can check the parts cars this evening when I get home and get back to you. It had a console in it. I will let you know either way if I have it. PM me your address and if I have one I will drop it in the mail to you. |
914Sixer |
Jun 27 2016, 05:37 AM
914 Guru Group: Members Posts: 8,875 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Top console bracket goes in to two white square plugs in the firewall. Nothing goes into dash pad.
iankarr |
Jun 27 2016, 08:59 PM
Thanks, Garold...will PM you my info.
Mark...the rubber nut/anchors on my car go into the metal under the dash...not the dash pad. No white square plugs on my '73. Both of the original rubber nut/anchors were there, but I pushed one up and in. Thanks guys! |
Lo-Fi Version | Time is now: 4th May 2024 - 04:54 PM |
