26 Pages V « < 20 21 22 23 24 > »
> Finally - GT project, Build of 914-6 GT
Mitox
post Dec 14 2025, 11:54 AM
Post #421
The banjo bolt for the master cylinder came in yesterday, so the brake lines are all in except for the connections to the calipers. I was able to reuse the reservoir to master cylinder clear plastic lines with the metal sections I had plated.
Mitox
post Dec 14 2025, 11:55 AM
Post #422
Mitox
post Dec 14 2025, 11:56 AM
Post #423
Master cylinder shot
Mitox
post Dec 14 2025, 12:05 PM
Post #424
Also, decided to go with the Empi axles from PMB.
Mitox
post Dec 14 2025, 01:24 PM
Post #425
Before moving on with the oil lines, the oil cooler and shroud needs to be fitted better. The lines are coming in from the passenger side, so patching the original holes is in work.
Mitox
post Dec 21 2025, 03:02 PM
Post #426
I have an odd question for anyone that knows:
I think one of these holes should remain open on the trailing arm. Does anyone remember which one? The hole on the trailing tip next to the shock mount, or the hole on the bottom?
I filled one of them, then doubted my memory
rgalla9146
post Dec 22 2025, 06:57 AM
Post #427
Both remain open.
What are the added brackets that extend away on the far side in the pic ?
Luke M
post Dec 22 2025, 07:24 AM
Post #428
QUOTE(rgalla9146 @ Dec 22 2025, 05:57 AM) *
Both remain open.
Looks like added brackets to hold a dust shield in place?
Any updates on the oil cooler install?
Mitox
post Dec 22 2025, 10:50 AM
Post #429
QUOTE(rgalla9146 @ Dec 22 2025, 07:57 AM) *
Both remain open.
Thanks for the response on the holes.
The added brackets are to mount the dust shield; I’m using the 911 e-brake setup, so the original mounts and shield can’t be used.
Mitox
post Dec 22 2025, 11:04 AM
Post #430
QUOTE(Luke M @ Dec 22 2025, 08:24 AM) *
Both remain open.
Oil cooler update:
I’ve been manipulating the metal shroud trying to get a better fit to the car’s contour with some success. The gaps are minimized to where a gasket should seal everything; I just purchased a gasket I’ll be trying out today. The shroud should be plug and play, but there are significant mismatches - maybe the shape is slightly different from the early cars?
Also, the Elephant Racing kit terminates in the front fender well, so I need to figure out the tube, hose, connections to the oil cooler. I would like to continue the plumbing with the 30mm connections, but that will require custom tube and or hose, so I may need to switch over to AN stuff.
post Dec 22 2025, 11:53 AM
Post #431
914-6 GT in waiting
It’s usually easier to use some metric to a/n adaptors than keep it metric all the way through.
Mitox
post Dec 23 2025, 01:18 PM
Post #432
Tried out the gasket today; it is 3/8” thick. I’ll need to try 1/4”, it takes to much force to compress the 3/8”.
After this is worked out, I’ll locate and install rivnuts. I’m thinking a few loadspreaders similar to what is used on valve covers would be useful also.
Mitox
post Dec 29 2025, 03:46 PM
Post #433
Yep, the 1/4” seal works very well. I located a few holes and klecos, but still need the rivnuts to complete the full install.
I’m also thinking of performing a little surgery in the shroud to make it removable without disconnecting the cooler hoses.
Mitox
post Dec 29 2025, 08:38 PM
Post #434
And, of course, the holes for attaching it to the oil cooler are randomly located.
Be prepared for rework if you get one of these metal shrouds - but that’s likely true of the fiberglass units also.
Mitox
post Dec 29 2025, 08:43 PM
Post #435
So, with the oil cooler connection holes relocated, and the screw holes modified, the oil cooler is in place for the first trial.
Now to make a mount under the oil cooler.
Mitox
post Jan 3 2026, 04:44 PM
Post #436
Oil cooler bottom mount is complete; the rivnuts will come soon.
Also, started installing the rivnuts for the shroud; they’re installed wet with ZRC. I’ll get the shroud back in place this evening to locate the remaining holes and plan for the intake grill.
Mitox
post Jan 6 2026, 02:17 PM
Post #437
Schedule change to get some parts painted- we’re having warm weather for a few days in the mountains of Virginia. I decided against powder coat on the trailing arms, so I’ll paint them and a few others parts I’ve been blasting. I think that only leaves the oil cooling ducting to paint.
Cairo94507
post Jan 7 2026, 08:07 AM
Post #438
Michael
Nice progress. (IMG:style_emoticons/default/beerchug.gif)
Mitox
post Jan 7 2026, 05:22 PM
Post #439
A little more today - painting parts feels good
Epoxy primer and top coat
Mitox
post Jan 7 2026, 05:23 PM
Post #440
- Lo-Fi Version Time is now: 28th July 2026 - 10:51 PM
