| Luke M |
Jan 8 2026, 07:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,563 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
So, with the oil cooler connection holes relocated, and the screw holes modified, the oil cooler is in place for the first trial. Now to make a mount under the oil cooler. Looking good. If you don't mind me asking but why add a mount under the cooler? I plan on mounting my cooler on the upper mounts only. I purchased the same cooler setup as you so I'm currently working through this as well. My cooler mounts nicely to the upper steel shroud that I have. Nothing hits anywhere when it's all in place. I want to add a few fans so dealing with that now. I wish PMB would do a step by step install vid so we all know the best way to tackle this. I just don't want a premature failure due to an improper installation. |
| Mitox |
Jan 8 2026, 12:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 551 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States
So, with the oil cooler connection holes relocated, and the screw holes modified, the oil cooler is in place for the first trial. Now to make a mount under the oil cooler. Looking good. If you don't mind me asking but why add a mount under the cooler? I plan on mounting my cooler on the upper mounts only. I purchased the same cooler setup as you so I'm currently working through this as well. My cooler mounts nicely to the upper steel shroud that I have. Nothing hits anywhere when it's all in place. I want to add a few fans so dealing with that now. I wish PMB would do a step by step install vid so we all know the best way to tackle this. I just don't want a premature failure due to an improper installation. The cooler is very light, so mounting only on the top is likely sufficient. I added the bottom mount for two reasons; first, I’m modifying the shroud to alllow easy removal while the oil cooler stays in place, and secondly, the original had a bottom mount in the center. |
| Mitox |
Jan 8 2026, 03:18 PM
| Luke M |
Jan 10 2026, 07:34 AM
More parts showed up at my door today. I’ll use this mesh for the oil cooler inlet and outlet. It’s a little smaller than the engine cover mesh, but the same style in stainless steel. The openings are roughly 6mm x 3.3mm I like that screen way better then what is currently installed on my screen cover. Could you share link or where you purchased it from? I got this from SMC and the screen is pretty flimsy. Attached image(s)
| Mitox |
Jan 10 2026, 11:29 AM
More parts showed up at my door today. I’ll use this mesh for the oil cooler inlet and outlet. It’s a little smaller than the engine cover mesh, but the same style in stainless steel. The openings are roughly 6mm x 3.3mm I like that screen way better then what is currently installed on my screen cover. Could you share link or where you purchased it from? I got this from SMC and the screen is pretty flimsy. It’s on the Amazon link below - note the actual opening size is a little smaller than the advertised 8mm x 4mm. https://www.amazon.com/dp/B0D74KXTPB?ref=pp..._title&th=1 |
| Mitox |
Jan 10 2026, 11:42 AM
So here’s my grill plan. After about 20 years, my Weber grill rusted away - except for the stainless top hatch door that I kept because it was good metal. My old grill will now become my 914 oil cooler intake grill. It is the perfect length, so if anyone has one of these Weber grills, now you know a better way to use it.
BTW - this one wasn’t my grill - mine collapsed from rust. |
| Mitox |
Jan 10 2026, 11:45 AM
| Mitox |
Jan 10 2026, 11:46 AM
| Mitox |
Jan 10 2026, 11:48 AM
| Mitox |
Jan 10 2026, 11:51 AM
| Mitox |
Jan 10 2026, 07:07 PM
| Mitox |
Jan 10 2026, 07:08 PM
| Mitox |
Jan 11 2026, 04:02 PM
| Mitox |
Jan 11 2026, 05:12 PM
| East coaster |
Jan 12 2026, 04:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,959 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None
Nice reuse of metal! You better get another one though, I heard 914s don’t run well with a single Weber (IMG:style_emoticons/default/smile.gif)
| Mitox |
Jan 26 2026, 12:27 PM
| Mitox |
Jan 26 2026, 12:29 PM
| Mitox |
Jan 26 2026, 12:30 PM
| Mitox |
Jan 28 2026, 03:20 PM
| Mitox |
Jan 28 2026, 09:28 PM
Lo-Fi Version | Time is now: 28th July 2026 - 10:51 PM |
