Question: Firewall repair, necessary or not |
slotty008 |
Jul 2 2016, 06:53 AM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
The car just came back from the bodyshop to replace the floor underneath the inner firewall and the front trunk floor. The stuff from Restoration Design is great.
But behind the passenger seat there's still a gap between the inner firewall and the floor. Is it necessary to weld this for the stiffness of the car or can I just use some epoxy to close the gap? |
barefoot |
Jul 2 2016, 06:58 AM
Senior Member Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
The car just came back from the bodyshop to replace the floor underneath the inner firewall and the front trunk floor. The stuff from Restoration Design is great. But behind the passenger seat there's still a gap between the inner firewall and the floor. Is it necessary to weld this for the stiffness of the car or can I just use some epoxy to close the gap? By all means, weld repair and even add a panel to double this area as it's part of the stiffness stricture. |
slotty008 |
Jul 2 2016, 07:41 AM
The car just came back from the bodyshop to replace the floor underneath the inner firewall and the front trunk floor. The stuff from Restoration Design is great. But behind the passenger seat there's still a gap between the inner firewall and the floor. Is it necessary to weld this for the stiffness of the car or can I just use some epoxy to close the gap? By all means, weld repair and even add a panel to double this area as it's part of the stiffness stricture. Not good news, but (IMG:style_emoticons/default/headbang.gif) I already thought so. |
cary |
Jul 2 2016, 08:19 AM
Did you remove the seam sealer?
slotty008 |
Jul 2 2016, 08:34 AM
iankarr |
Jul 2 2016, 08:42 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,482 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Rust likes to hide under the seam sealer.
Jul 2 2016, 08:48 AM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The car just came back from the bodyshop to replace the floor underneath the inner firewall and the front trunk floor. The stuff from Restoration Design is great. But behind the passenger seat there's still a gap between the inner firewall and the floor. Is it necessary to weld this for the stiffness of the car or can I just use some epoxy to close the gap? What kind of shop would replace the floor but not fix that part? (IMG:style_emoticons/default/confused24.gif) Either way, that *is* structural and needs to be fixed. And no, epoxy or bondo is not a fix. (IMG:style_emoticons/default/shades.gif) |
slotty008 |
Jul 2 2016, 09:00 AM
The car just came back from the bodyshop to replace the floor underneath the inner firewall and the front trunk floor. The stuff from Restoration Design is great. But behind the passenger seat there's still a gap between the inner firewall and the floor. Is it necessary to weld this for the stiffness of the car or can I just use some epoxy to close the gap? What kind of shop would replace the floor but not fix that part? (IMG:style_emoticons/default/confused24.gif) Either way, that *is* structural and needs to be fixed. And no, epoxy or bondo is not a fix. (IMG:style_emoticons/default/shades.gif) I simply don't understand why they didn't fix that.There's gonna be a very furious phone call monday morning. |
Mark Henry |
Jul 2 2016, 09:08 AM
With that kind of damage I would not only repair it proper, but I'd also add an inner long stiffener kit.
cary |
Jul 2 2016, 09:14 AM
The car just came back from the bodyshop to replace the floor underneath the inner firewall and the front trunk floor. The picture your showing us is the inner firewall ............ but looks like old floor. Show us where your at now. Maybe more pictures showing both sides. |
Mueller |
Jul 2 2016, 12:14 PM
I'd fix it properly...fumes and possibly flames getting into the cabin from that location would have me a little nervous.
Rand |
Jul 2 2016, 12:21 PM
If you can see air between the ragged edges of rusty decay, after you got it back from a "body shop"...
Makes me sad what some "shops" put out. |
slotty008 |
Jul 2 2016, 12:52 PM
I'm in the middle of a bbq party( time difference), so I will get back to you guys later this day.
slotty008 |
Jul 2 2016, 04:07 PM
The car just came back from the bodyshop to replace the floor underneath the inner firewall and the front trunk floor. The picture your showing us is the inner firewall ............ but looks like old floor. Show us where your at now. Maybe more pictures showing both sides. It's the floor just behind the inner firewall they replaced.The other side is OK. The floor behind the seats is OK. |
slotty008 |
Jul 2 2016, 04:18 PM
If you can see air between the ragged edges of rusty decay, after you got it back from a "body shop"... Makes me sad what some "shops" put out. |
Rand |
Jul 2 2016, 04:28 PM
If you can see air between the ragged edges of rusty decay, after you got it back from a "body shop"... Makes me sad what some "shops" put out. This is the air I see. And that's one horrible ass faultline. (IMG:style_emoticons/default/barf.gif) |
cary |
Jul 2 2016, 05:33 PM
The portion behind the inner firewall is the portion enclosed between the two firewalls.
The portion in the red circle. Did they take pictures? The pictures your showing us is in the yellow circle. If they can assure you the flange in the yellow circle isn't consumed by the rust worm. Then it's a different story. Did they do any kind of rust treatment/neutralization ? |
barefoot |
Jul 2 2016, 07:26 PM
The portion behind the inner firewall is the portion enclosed between the two firewalls. The portion in the red circle. Did they take pictures? The pictures your showing us is in the yellow circle. If they can assure you the flange in the yellow circle isn't consumed by the rust worm. Then it's a different story. Is there a larger cross section view of this area on hand, I'd like to understand this area more completely Thanks |
slotty008 |
Jul 3 2016, 05:30 AM
If you can see air between the ragged edges of rusty decay, after you got it back from a "body shop"... Makes me sad what some "shops" put out. This is the air I see. And that's one horrible ass faultline. (IMG:style_emoticons/default/barf.gif) What you see is the floor pan painted grey. There's no light coming through, not from the engine compartment and not from underneath the car. |
slotty008 |
Jul 3 2016, 05:39 AM
The portion behind the inner firewall is the portion enclosed between the two firewalls. The portion in the red circle. Did they take pictures? The pictures your showing us is in the yellow circle. If they can assure you the flange in the yellow circle isn't consumed by the rust worm. Then it's a different story. Did they do any kind of rust treatment/neutralization ? I tried to get in with a screwdriver. I can only get in 1inch approximately.Then it feels really sound. |
Lo-Fi Version | Time is now: 17th June 2024 - 05:34 AM |
