Fuel gauge needle "ticks" in time with turn signal. Any idea why? |
Cuda911 |
Jul 3 2016, 08:10 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Odd, the needle on my fuel gauge "ticks" (moves back and forth slightly, a millimeter or so) in time with my turn signals, when the turn signals are on. Anyone seen that before or know why? I assume some sort of grounding issue.
914Sixer |
Jul 3 2016, 09:06 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
What year car?
Cuda911 |
Jul 3 2016, 11:22 PM
'73 1.7
I can probably make a video if it's not clear what I mean. |
Jul 3 2016, 11:24 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The ground isn't staying a ground, or the power to the gauge isn't staying at full voltage.
--DD |
ConeDodger |
Jul 3 2016, 11:38 PM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The ground isn't staying a ground, or the power to the gauge isn't staying at full voltage. --DD (IMG:style_emoticons/default/agree.gif) |
jim_hoyland |
Jul 4 2016, 09:29 AM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
My tach needle does the same ???? (IMG:style_emoticons/default/sad.gif)
Larmo63 |
Jul 4 2016, 10:22 AM
Clean all the grounds under the dash to the ground stub on the chassis.
Located under the fuse box to the side. Clean each wire individually. |
Jul 4 2016, 10:42 PM
Fuse #8 (I think?) being popped can cause similar symptoms, if your tach is jumping around. Check, remove, and clean all fuses and the fuse holders.
--DD |
Lo-Fi Version | Time is now: 1st June 2024 - 11:50 PM |
