Cuda911
Jul 3 2016, 08:10 PM
Odd, the needle on my fuel gauge "ticks" (moves back and forth slightly, a millimeter or so) in time with my turn signals, when the turn signals are on. Anyone seen that before or know why? I assume some sort of grounding issue.
914Sixer
Jul 3 2016, 09:06 PM
What year car?
Cuda911
Jul 3 2016, 11:22 PM
'73 1.7
I can probably make a video if it's not clear what I mean.
Dave_Darling
Jul 3 2016, 11:24 PM
The ground isn't staying a ground, or the power to the gauge isn't staying at full voltage.
--DD
ConeDodger
Jul 3 2016, 11:38 PM
QUOTE(Dave_Darling @ Jul 4 2016, 01:24 AM)
--DD
jim_hoyland
Jul 4 2016, 09:29 AM
My tach needle does the same ????
Larmo63
Jul 4 2016, 10:22 AM
Clean all the grounds under the dash to the ground stub on the chassis.
Located under the fuse box to the side. Clean each wire individually.
Dave_Darling
Jul 4 2016, 10:42 PM
Fuse #8 (I think?) being popped can cause similar symptoms, if your tach is jumping around. Check, remove, and clean all fuses and the fuse holders.
--DD
