wiring pilot fog lights, my harness might be funky |
buck toenges |
Jul 4 2016, 07:56 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I am confused about wiring up my pilot fog lamps. I have a brown ground wire with a female connector and two why/yellow stripe wires that are soldiered together. How do I hook up the white/yellow stripe wires to the fog light?
Thanks, Buck |
914Sixer |
Jul 4 2016, 08:33 PM
White/yellow strip is hot from switch. Brown is ground to light.
buck toenges |
Jul 11 2016, 11:05 AM
Here are a couple of pictures to explain my dilemma. I don't know how to hook up the white/yellow stripe wires to the fog light. There are possibly 2 male connectors on the housing but I am not sure one is actually a male connector. Do I hook up the wire to the copper area on the light bulb area itself?
JeffBowlsby |
Jul 11 2016, 11:39 AM
914 Wiring Harnesses Group: Members Posts: 8,503 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Maybe if your photos were a bit more clear and close-up we could actually help you. (IMG:style_emoticons/default/blink.gif)
Those are the correct wires you need. Don't cut or modify them, just add the right connections to mate with your lights. The passenger side only has 1 yellow/white with one brown. |
Lo-Fi Version | Time is now: 13th May 2024 - 11:44 PM |
