I am confused about wiring up my pilot fog lamps. I have a brown ground wire with a female connector and two why/yellow stripe wires that are soldiered together. How do I hook up the white/yellow stripe wires to the fog light?
Thanks, Buck
914Sixer
Jul 4 2016, 08:33 PM
White/yellow strip is hot from switch. Brown is ground to light.
buck toenges
Jul 11 2016, 11:05 AM
Here are a couple of pictures to explain my dilemma. I don't know how to hook up the white/yellow stripe wires to the fog light. There are possibly 2 male connectors on the housing but I am not sure one is actually a male connector. Do I hook up the wire to the copper area on the light bulb area itself?
JeffBowlsby
Jul 11 2016, 11:39 AM
Maybe if your photos were a bit more clear and close-up we could actually help you.
Those are the correct wires you need. Don't cut or modify them, just add the right connections to mate with your lights. The passenger side only has 1 yellow/white with one brown.
