914 TURBO CARRERA UPDATE 4/9/05 |
iamchappy |
Apr 9 2005, 11:51 AM
I was able to get the car out today and give it an easy breakin drive, The turbo comes on much sooner than the old Rayjay, It hits around 2800 - 3000 RPM as opposed to the 3800 from the old turbo setup, it's too soon to tell if it is as powerful as the old Rayjay as I am breaking in the turbo slowly and have not raised the boost up yet. I am sure there is some pressure drop with the intercooler installed. I will log in some miles over the weekend check and recheck all systems then give you a all systems go, throttle up report on the butt dyno. (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
iamchappy |
Apr 9 2005, 02:43 PM
OH, OH very bad noise coming from engine. Car was running and sounding great and I have been driving it easy all day, I stopped for awhile at the neighbors when I got back in to drive it 2 blocks home it developed a bad noise and my oil pressure gauge shows low pressure, hoping a tensioner but sounds a lot like rod bearing noise, and the low oil pressure? The engine stills seems to run smooth I may be down for awhile till I figure this one out. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Qarl |
Apr 9 2005, 02:50 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
iamchappy |
Apr 9 2005, 03:05 PM
No, it really sounds a lot like a rod bearing knock or a main bearing knock and the low oil pressure along with it, it seems odd that it would just happen all at once like that after sitting for a half hour and driving 2 blocks home. I replaced the oil pressure ending unit last week, I am hoping its more like tensioner failure.
iamchappy |
Apr 9 2005, 04:11 PM
Ok this is what I found, I drained the oil out and checked the magnetic plug and found some shavings but nothing that looks abnormal, I removed the sump screen and found a few particals that looked like shavings and may of been something that found its way into the case when I tapped the fittings for the oil pump in the cam, Looking further now that all the oil is cleaned up.
OH MY (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif), the oil pump shaft is broken at the spline end where the cerclip attaches oppisite the pump. Answer to the low oil pressure, I hope the rod bearing didnt fail in those two blocks I drove and the noise is related to the oil pump either way looks like my engine is going to have to have a major operation. And while im in there.................. Holy shit this is going to cost me $ :woohoo:and my whole summer. Just when it looked like I was ready to get everything finished up. Sorry guys you and I will have to wait to see the test results. |
Aaron Cox |
Apr 9 2005, 04:15 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
aww man..... sorry man (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 07:25 PM |
