it runs and it cools sort of, and i took it for a drive |
scotty914 |
Apr 9 2005, 03:10 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
well i fixed the wiring, even upgraded some wiring while in there like added fuses where there when NONE on wires that connect to the battery directly. added a few grounds because when it melted down one of the things that took the most damage was the ground wires.
then i took here for a drive out on the highway about a 40 min drive, it got hot but not hot enough to over heat. at this point the scoop is not even attached to the bottom of the radiator, there is about a 1.5 inch gap. i did this as a test as a worse case, i know once i seal it up it will be better. also it does not cool fast enough for me at lights with one fan so today i am going to install another. |
Lo-Fi Version | Time is now: 26th May 2024 - 01:47 PM |
