Removal of tits on '73, Do I need to remove the bumper |
914Next |
Jul 12 2016, 11:11 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Traveling and not doing a great job of search on my iPhone. Wondering if someone can tell me if I need to remove the bumper in order to remove tits on my '73? Are these an easy thing to remove? Thanks.
Steve |
Wyvern |
Jul 12 2016, 11:38 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
Yes ... you need to remove the bumper .
BUT that is super easy. Just 4 bolts 2 on each side (in the wheel well) Then you will see the bolts for the tits .. (ha ha ha . "tit bolts" LOL) |
Chris914n6 |
Jul 13 2016, 12:14 AM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I think you can get to them after removing the grills.
PanelBilly |
Jul 13 2016, 06:47 AM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Then you weld up the holes and have it painted or chromed. Makes for a really clean look. I had the licence plate holes filled too
gcrotvik |
Jul 13 2016, 07:04 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I don't believe you can get to both bolts by just removing the grills. The bolts are on each side of the inner steel and rubber bumper block. You will need to remove the bumper completely.
I think Steve is replacing old tits with new tits. Greg |
Jul 13 2016, 07:35 AM
914-6 GT in waiting Group: Members Posts: 19,269 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I bet you can remove the grill and reach in and remove the two nuts. I doubt yours are even rusty.
gcrotvik |
Jul 13 2016, 07:59 AM
I don't believe you can get to both bolts by just removing the grills. The bolts are on each side of the inner steel and rubber bumper block. You will need to remove the bumper completely. I think Steve is replacing old tits with new tits. Greg You will need to get under the strap and rubber buffer. See the picture. There is a steel sub plate that slides under the strap and buffer that bolts on to the back of the tit mounting screws (not shown in the picture). Attached thumbnail(s) |
Tom_T |
Jul 13 2016, 12:02 PM
I bet you can remove the grill and reach in and remove the two nuts. I doubt yours are even rusty. Mark - Steve has fog lights in the way of the tit bolts, plus the backer shown by Greg is in the way. So the bumper has to come off. That way he can clean the backside (IMG:style_emoticons/default/bootyshake.gif) of the bumper for his next concours event too! Nothing like a fresh set of tits! (IMG:style_emoticons/default/first.gif) Cheers Steve! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Jul 13 2016, 12:27 PM
I bet you can remove the grill and reach in and remove the two nuts. I doubt yours are even rusty. Mark - Steve has fog lights in the way of the tit bolts, plus the backer shown by Greg is in the way. So the bumper has to come off. That way he can clean the backside (IMG:style_emoticons/default/bootyshake.gif) of the bumper for his next concours event too! Nothing like a fresh set of tits! (IMG:style_emoticons/default/first.gif) Cheers Steve! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Fog lights don't take up the whole space. There is still space behind the tit bolts and the backer. You can't just assume it won't work. |
PanelBilly |
Jul 13 2016, 09:57 PM
914Next |
Jul 15 2016, 02:28 PM
Thanks Guys. I think I'll take the bumpers off since, as Tom says, it will give me a chance to clean more. Also will likely replace one tit since there is a slight cut on it and I was able to find two nos ones.
Will take pics and let you know how it goes. Steve |
914Next |
Jul 15 2016, 04:58 PM
Well that was easy. Decided to go out and tackle the bumper today. Biggest issues was finding my small ratchet that fit up near the bumper bolts. The front panel and bumper looks really good. Even the bolts and attaching hardware still have there yellow cad plating. Took some before and after (a quick cleaning)
Before |
914Next |
Jul 15 2016, 05:02 PM
dlkawashima |
Jul 15 2016, 05:05 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Amazingly clean if that's the first time the bumper has been off the car. (IMG:style_emoticons/default/first.gif)
914Next |
Jul 15 2016, 05:07 PM
pete000 |
Always sad that the Tits deform the bumper causing a lot of metal work to have them re chromed.
914Next |
Jul 15 2016, 05:08 PM
Amazingly clean if that's the first time the bumper has been off the car. (IMG:style_emoticons/default/first.gif) It is Dave. I was pleased with what I found! The original owner never removed it. |
914Next |
Jul 15 2016, 05:10 PM
Always sad that the Tits deform the bumper causing a lot of metal work to have them re chromed. Yeah I was surprised to see that. Is that from a light tap at some point or does this happen even without hitting something. I'll leave it as is since its an original car. |
Blue6 |
Jul 15 2016, 09:18 PM
Senior Member Group: Members Posts: 1,035 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
Always sad that the Tits deform the bumper causing a lot of metal work to have them re chromed. Yeah I was surprised to see that. Is that from a light tap at some point or does this happen even without hitting something. I'll leave it as is since its an original car. I agree, it's better to leave it original. If you put larger tits on you can expect problems with leakage, and possibly have to re stuff them every 5 yrs. (IMG:style_emoticons/default/biggrin.gif) |
914Next |
Jul 16 2016, 07:28 AM
.....and finished this am. Thanks guys for the help!
Lo-Fi Version | Time is now: 13th May 2024 - 08:49 PM |
