A Texas Sized Project - 1975 2.0L, 12/8/20 - Wiring & Interior Update |
aggiezig |
Jul 13 2016, 03:31 PM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
Hi 914World,
New(ish) member with new project - a 1975 2.0L. It's certainly a project, but I think it's a great starting place. The seller is extremely knowledgeable about the car and helpful with local contacts who are in the 914 scene. It's been on the local CL for a while for more than I wanted to pay, but was recently able to strike a deal. Here are some specs about the project:
2055cc "build" project in pieces currently (with matching numbers)
Looking forward to this one! |
aggiezig |
Mar 23 2017, 09:20 AM
Finally got a chance to get in the garage and play last night. Doesn't look like much, but was a few hours worth of fitting and welding.
Hell hole / Top of Long patch fitted to size: (IMG:http://www.914world.com/bbs2/uploads_offsite/i120.photobucket.com-19557-1490282442.1.jpg) Welded in place (still need to grind and fill holes) (IMG:http://www.914world.com/bbs2/uploads_offsite/i120.photobucket.com-19557-1490282442.2.jpg) Also made a new piece for the passenger side sail panel and got this welded in. I was way down on the welder (A-1.5) and used compressed air after each weld to try and prevent and warpage. I think we did ok, but will have to grind and block to see if there is anything serious. (IMG:http://www.914world.com/bbs2/uploads_offsite/i120.photobucket.com-19557-1490282443.3.jpg) I'm still not sure if I am going to attempt to cut open the driver's side just for peace of mind. The inside of the passenger sail was very clean with no real rot to speak of. I'm wondering if I can find a way to drill / cut a small hole and "melt" the foam out with heat or chemicals. Then spray in some Master Series as future rust prevention. Not sure... I still need to re-create the missing engine shelf, patch the firewall, and replace the missing engine seal track. And then still need to tack in the battery tray and muffler heat shield. Possibly some of that this weekend? I also have a bit of patch work left to do up where the front trunk seal channel is. There are definitely some crunchy corners that will need replaced. But, once that work is done I think I will be almost done with all metal repairs? Oh... except for the emergency brake pivot mount that is missing a pivot. The list never ends. (IMG:style_emoticons/default/sawzall-smiley.gif) Lastly, I discovered two weeks ago when crawling around in the engine bay that the PO, for some reason unbeknownst to me, decided to remove both the rear trunk hinge pivot mounts and then lose one of the brackets. So, rather than fight with welding the OE style mount back in place, I broke down and ordered the J West Engineering kit with heim joints. I also ordered front & rear strut kits from Camp. Should be a nice upgrade. When life gives you lemons... |
Lo-Fi Version | Time is now: 17th May 2024 - 07:22 AM |
