> A Texas Sized Project - 1975 2.0L, 12/8/20 - Wiring & Interior Update
aggiezig
post Jul 13 2016, 03:31 PM
Post #181
Porsche Wannabe
Hi 914World,
New(ish) member with new project - a 1975 2.0L. It's certainly a project, but I think it's a great starting place. The seller is extremely knowledgeable about the car and helpful with local contacts who are in the 914 scene. It's been on the local CL for a while for more than I wanted to pay, but was recently able to strike a deal. Here are some specs about the project:
  • "Rust Free" car with the only rust being on the surface of cleaned metal
  • Hell-hole looks very clean
  • All original glass, bumpers, interior, suspension, rims, etc. are included
  • 901 "side shift" transmission has been taken apart, inspected, and rebuilt
  • Lowered hard mounts for drivetrain
  • There are some spares included as well (doors, top, misc. / etc.)
The engine is the gem of this purchase in my opinion. Here are the details:
2055cc "build" project in pieces currently (with matching numbers)
  • All balanced / clearance as necessary by H&H in Dallas
  • 96mm Pistons / Cylinders
  • 9.0:1 compression ratio
  • 3-angle valve job on 2.0 Heads
  • Iskenderian Cams #485128 Grind #VP-228
  • Claude's Buggies' Lightened Lifters
  • Lightened Flywheel
  • Custom High RPM Cooling Fan
  • Rotating assembly has been coated with polymer or ceramic coatings by Polymer Dynamics in Houston
I've put down a deposit to hold and will be picking up on Monday. I'll post pictures as soon as I can. Plans are for a mostly stock rebuild with an attempt to retain as much value as possible.
Looking forward to this one!
aggiezig   A Texas Sized Project - 1975 2.0L   Jul 13 2016, 03:31 PM
Frankvw   Welcome. Good luck with the pickup. Looking forwar...   Jul 13 2016, 03:38 PM
theleschyouknow   :wttc: glad to see another Texan on the board sou...   Jul 13 2016, 04:10 PM
76-914   :wttc: and I would like to see a pic of that speci...   Jul 13 2016, 04:38 PM
Shadowfax   :wttc: From NW Louisiana. :white914:   Jul 13 2016, 05:19 PM
aggiezig   As promised, here are some pics. From the origina...   Jul 13 2016, 07:44 PM
aggiezig   Oops - found some additional pics from original ad...   Jul 13 2016, 07:50 PM
barefoot   Oops - found some additional pics from original a...   Jul 14 2016, 06:52 PM
zambezi   curious about that fan with the axial flow impell...   Jul 14 2016, 10:33 PM
aharder   :wttc:   Jul 14 2016, 04:17 AM
Beebo Kanelle   Gig 'Em   Jul 14 2016, 05:30 AM
Grelber   Was the engine one that Wes did?   Jul 14 2016, 07:52 AM
aggiezig   Was the engine one that Wes did? Will have to c...   Jul 14 2016, 07:57 AM
blackmoon   :wttc: It looks like you have your work cut out fo...   Jul 14 2016, 08:27 AM
H&H1981   H&H is still open, in case you have heard diff...   Jul 14 2016, 09:24 AM
aggiezig   H&H is still open, in case you have heard dif...   Jul 14 2016, 09:27 AM
stuttgart46   Great to see another 914 in Texas.   Jul 14 2016, 04:33 PM
aggiezig   Will see what I can find out on the fan. No big up...   Jul 17 2016, 11:06 PM
rjames   I'd look closely at the hell hole again. May...   Jul 18 2016, 10:25 PM
Elliot Cannon   It will be a bit of work but when done it will be ...   Jul 18 2016, 11:18 PM
aggiezig   Just thought I would share real quick - I picked u...   Jul 18 2016, 11:41 PM
aggiezig   Ok, as promised here are some much better pictures...   Jul 19 2016, 09:09 AM
theleschyouknow   longs look good in the pic I'd check the b pil...   Jul 19 2016, 02:07 PM
aggiezig   The organization has begun! I went through all...   Jul 20 2016, 09:22 AM
Claus Graf   Congrats! Looks like you got a solid 914 with ...   Jul 20 2016, 12:52 PM
aggiezig   So, today she is a roadster again: http://www.914...   Jul 22 2016, 07:53 PM
Rob-O   The organization has begun! I went through al...   Jul 22 2016, 09:17 PM
Rob-O   The foam piece in your last pic is the passenger s...   Jul 22 2016, 09:24 PM
Rob-O   Red inserts in the seat aren't original. But ...   Jul 22 2016, 09:28 PM
Rob-O   Sorry to keep adding posts, but just saw another p...   Jul 22 2016, 09:50 PM
Larmo63   I feel sorry for you, I really do. You've cau...   Jul 22 2016, 11:03 PM
barefoot   2055cc "build" project in pieces current...   Jul 23 2016, 06:14 AM
cuddyk   :wttc: Congrats! Looks like you've got pl...   Jul 23 2016, 06:41 AM
charliew   Welcome to the world site. My son is a aggie me su...   Jul 24 2016, 10:09 AM
aggiezig   Rob-O - thanks for the help / advice. Much appreci...   Jul 24 2016, 10:56 AM
aggiezig   After a sweat-filled couple of hours this afternoo...   Jul 24 2016, 09:06 PM
Rob-O   After a sweat-filled couple of hours this afterno...   Jul 24 2016, 09:35 PM
aggiezig   Quick update. I've spent a couple of nights wo...   Jul 28 2016, 09:45 AM
Rob-O   I would replace for peace of mind. I'm sure y...   Jul 28 2016, 11:37 AM
aggiezig   Tonight I went through my cases of engine parts to...   Aug 2 2016, 10:42 PM
aggiezig   Spent the evening with Jay @ H&H in Plano. Gre...   Aug 3 2016, 08:48 PM
aggiezig   Pulled the 'teener out to load up and move fro...   Aug 11 2016, 11:08 AM
aggiezig   Picked up the parts car this afternoon. It's a...   Aug 14 2016, 10:11 PM
porschetub   Looks like a good sound base for a resto,not as ro...   Aug 15 2016, 03:51 PM
aggiezig   Quick update for you guys. I pulled the front susp...   Sep 24 2016, 10:55 PM
aggiezig   Got the parts car moved out of my storage unit and...   Oct 4 2016, 10:05 PM
Larmo63   There are some parts that you intend to powder coa...   Oct 4 2016, 10:55 PM
aggiezig   Picked up some shiny clean parts today... http://...   Oct 17 2016, 04:51 PM
aggiezig   I was inspired by the octagon / rotisserie that Re...   Oct 30 2016, 09:29 PM
Cairo94507   Nice project and you are making good time too. I ...   Nov 1 2016, 08:12 AM
aggiezig   Thanks, Cairo. I definitely appreciate his help. ...   Nov 2 2016, 09:12 PM
aggiezig   All done... just needs a 914 inside of it! ht...   Nov 5 2016, 10:24 PM
aggiezig   It was a little bit of a challenge, but my 914 is ...   Nov 6 2016, 06:14 PM
mbseto   Nice work. I'm kind of fascinated by these oc...   Nov 7 2016, 11:02 AM
aggiezig   Spent a little time this weekend working on some o...   Nov 16 2016, 09:34 PM
aggiezig   Well, it's been a month but I was finally able...   Dec 11 2016, 06:44 PM
aggiezig   Time for a few updates… While I was out of town,...   Jan 15 2017, 07:58 PM
aggiezig   Playing around with some paint stripper... http:/...   Jan 18 2017, 11:42 PM
Vacca Rabite   Decided not to blast it? Zach   Jan 19 2017, 01:55 PM
aggiezig   Decided not to blast it? Zach I'm weighing ...   Jan 19 2017, 02:22 PM
aggiezig   Time for some sheet metal updates.... Here's ...   Jan 23 2017, 12:22 PM
aggiezig   Next up... front trunk floor! The front panel ...   Jan 23 2017, 12:35 PM
aggiezig   I've been making a lot of progress on unexpect...   Feb 9 2017, 10:56 PM
aggiezig   Well, this will be a pretty big update. After spot...   Feb 11 2017, 11:01 PM
Cairo94507   Very nice working documentation. That is going to...   Feb 12 2017, 08:09 AM
jmitro   nice work. Looked exactly like my crusty old car   Feb 12 2017, 08:59 AM
aggiezig   Thanks for the kind words, gents. Small update, b...   Feb 28 2017, 10:41 PM
StratPlayer   Amazing job, well done :first: :first:   Mar 1 2017, 05:23 PM
76-914   Grinding down rosette welds takes the Fun right ou...   Mar 1 2017, 07:36 PM
aggiezig   Amazing job, well done :first: :first: Thank...   Mar 1 2017, 10:32 PM
Cairo94507   :popcorn: :popcorn:   Mar 2 2017, 07:21 AM
aggiezig   The repair saga continues... doubler is in and so ...   Mar 2 2017, 11:10 PM
aggiezig   Small update... I just got a truck load of parts b...   Mar 21 2017, 03:22 PM
aggiezig   Finally got a chance to get in the garage and play...   Mar 23 2017, 09:20 AM
aggiezig   Time for another update! Today we finished up ...   Mar 25 2017, 11:12 PM
aggiezig   Took her out, flipped her over, and got her wet. :...   Mar 26 2017, 11:02 PM
aggiezig   Gotta keep going while I'm on a roll... I us...   Mar 27 2017, 10:46 PM
aggiezig   Some small updates, but first a little day-dreamin...   Apr 3 2017, 11:54 PM
jesse7flying   Great work and great thread! I've got the...   Apr 4 2017, 09:51 AM
aggiezig   Great work and great thread! I've got th...   Apr 4 2017, 08:57 PM
aggiezig   Took the plunge last night and decided there was n...   Apr 6 2017, 08:26 AM
aggiezig   Spent most of today at the Mecum auction in Housto...   Apr 8 2017, 10:24 PM
aggiezig   Few more repairs done... Here is the passenger lo...   Apr 10 2017, 12:10 PM
aggiezig   If you will recall, I was missing both factory tru...   Apr 12 2017, 03:57 PM
76-914   If you will recall, I was missing both factory tr...   Apr 12 2017, 04:50 PM
aggiezig   You could have welded that in place. Probably not...   Apr 12 2017, 11:28 PM
aggiezig   My hell hole repair is finally completed!...   Apr 14 2017, 09:29 PM
aggiezig   Here's a nice break from all the metal work......   Apr 30 2017, 08:37 PM
aggiezig   Work has picked up and progress has screeched to a...   May 15 2017, 10:31 PM
barefoot   Also bought a 3-4 side passenger tin as the one I ...   Sep 11 2017, 04:46 AM
aggiezig   Wow long time, no post. Life has gotten in the way...   Jul 9 2017, 10:54 PM
Larmo63   You aren't going to use the cooling flaps and ...   Jul 9 2017, 11:53 PM
aggiezig   You aren't going to use the cooling flaps and...   Jul 10 2017, 08:04 AM
jesse7flying   +1 on the Adriatic Blue. My 914 has been painted ...   Jul 10 2017, 09:26 AM
aggiezig   If you missed my other thread, I'm choosing ha...   Jul 23 2017, 10:46 PM
mbseto   I wish my "pecking away every now and then...   Jul 24 2017, 07:32 AM
aggiezig   I wish my "pecking away every now and then...   Jul 25 2017, 10:30 PM
aggiezig   Hello world, time for an update! Progress has ...   Sep 10 2017, 11:10 PM
porschetub   Very impressed have been following progress....POS...   Sep 11 2017, 12:28 AM
Tbrown4x4   I didn't see if anybody answered your question...   Sep 11 2017, 03:09 AM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 24th September 2026 - 10:26 AM
